주요 콘텐츠로 건너뛰기
DJI Mini 2 Gimbal Camera Replacement
필요한 것
동영상 개요
  1. DJI Mini 2 Gimbal Camera Replacement, Battery: 1 단계, 이미지 1/2 DJI Mini 2 Gimbal Camera Replacement, Battery: 1 단계, 이미지 2/2
    • Face the DJI Mini 2 away from you so that you are looking at the charging ports.
    • Use your finger to open up the back panel.
  2. DJI Mini 2 Gimbal Camera Replacement: 2 단계, 이미지 1/2 DJI Mini 2 Gimbal Camera Replacement: 2 단계, 이미지 2/2
    • Pinch the locking mechanism on the battery to release the lock.
    • Pull the battery straight out of the compartment.
  3. DJI Mini 2 Gimbal Camera Replacement, Drone Body: 3 단계, 이미지 1/2 DJI Mini 2 Gimbal Camera Replacement, Drone Body: 3 단계, 이미지 2/2
    • Unfold the wings of the drone.
    • Place the drone upside down on a flat surface.
    • There should be stickers on the device telling you how to unfold the propeller arms.
  4. DJI Mini 2 Gimbal Camera Replacement: 4 단계, 이미지 1/2 DJI Mini 2 Gimbal Camera Replacement: 4 단계, 이미지 2/2
    • Remove the four 5 mm J000 screws near each propeller arm.
  5. DJI Mini 2 Gimbal Camera Replacement: 5 단계, 이미지 1/3 DJI Mini 2 Gimbal Camera Replacement: 5 단계, 이미지 2/3 DJI Mini 2 Gimbal Camera Replacement: 5 단계, 이미지 3/3
    • Flip the drone back over.
    • Use a combination of the opening tool and your fingers to pry open the top panel of the drone along the seams.
  6. DJI Mini 2 Gimbal Camera Replacement: 6 단계, 이미지 1/2 DJI Mini 2 Gimbal Camera Replacement: 6 단계, 이미지 2/2
    • Remove the two 5 mm J000 screws located in the battery hatch and near the ports on the back of the drone.
  7. DJI Mini 2 Gimbal Camera Replacement: 7 단계, 이미지 1/2 DJI Mini 2 Gimbal Camera Replacement: 7 단계, 이미지 2/2
    • Flip the drone over again.
    • Pry off the bottom panel of the drone using the opening tools and your fingers.
  8. DJI Mini 2 Gimbal Camera Replacement, Main Board: 8 단계, 이미지 1/3 DJI Mini 2 Gimbal Camera Replacement, Main Board: 8 단계, 이미지 2/3 DJI Mini 2 Gimbal Camera Replacement, Main Board: 8 단계, 이미지 3/3
    • Remove the three 3mm J000 screws on the black plate.
  9. DJI Mini 2 Gimbal Camera Replacement: 9 단계, 이미지 1/2 DJI Mini 2 Gimbal Camera Replacement: 9 단계, 이미지 2/2
    • Use your fingers to pull the black plate off to reveal main board.
  10. DJI Mini 2 Gimbal Camera Replacement: 10 단계, 이미지 1/3 DJI Mini 2 Gimbal Camera Replacement: 10 단계, 이미지 2/3 DJI Mini 2 Gimbal Camera Replacement: 10 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Try to avoid disturbing the blue thermal paste covering two of the large board components. If the paste is disturbed or splotchy in places it may need to be removed and reapplied. For more information refer to the How to Apply Thermal Paste guide.
    • Using ESD Safe Tweezers Blunt Nose, remove the 5 cables attached to the main board.
  11. DJI Mini 2 Gimbal Camera Replacement: 11 단계, 이미지 1/2 DJI Mini 2 Gimbal Camera Replacement: 11 단계, 이미지 2/2
    • Use the ESD Safe Tweezers Blunt Nose and your fingers to pull off the main board from the drone carriage.
  12. DJI Mini 2 Gimbal Camera Replacement, Gimbal Camera: 12 단계, 이미지 1/2 DJI Mini 2 Gimbal Camera Replacement, Gimbal Camera: 12 단계, 이미지 2/2
    • Use your hands to remove the camera cover.
  13. DJI Mini 2 Gimbal Camera Replacement: 13 단계, 이미지 1/1
    • Pull the cable that was once attached to the mainboard and attaches to the camera through the main body.
  14. DJI Mini 2 Gimbal Camera Replacement: 14 단계, 이미지 1/2 DJI Mini 2 Gimbal Camera Replacement: 14 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use the tweezers to pull the four rubber camera holsters off of the body.
  15. DJI Mini 2 Gimbal Camera Replacement: 15 단계, 이미지 1/1
    • Using the J000 screwdriver, remove the two remaining 3 mm screws connecting the camera to the body.
    • Remove the camera.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Parker Sowersby
회원 가입일: 03/28/22
289 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team F-1, Gurgel Spring 2022 UMass Dartmouth, Team F-1, Gurgel Spring 2022 회원
UMASSD-GURGEL-S22SFG1
2 회원들
안내서 15개 작성하였습니다
댓글 7개
this guide is missing so many steps its ridiculous
Ben Coleman - 답글
Hi Ben, thank you for the constructive criticism, but this is what happens when you make “creating a guide” a class requirement for a grade rather then hire professionals. I personally had no idea what I was doing writing this and just wanted to get my grade. So unfortunately, this guide will not be updated.
Parker Sowersby -
Check out the video guide
Arty -
Thank you very much for your tutorial. I successfully managed to replace my broken camera assembly. Maybe you should mention how to insert gimbal back (not as easy as it seems). With the official part, you have to use pliers to pull the little rubber parts. And even with an official part, you will always have a warning message about calibration. We can’t do anything for this except sending the drone to dji. Even if the calibration is fine and the drone perfectly working, there is this anti self repair « protection »… Only a certified DJI technician/shop can remove the error.
Gauthier Heiss - 답글
Thanks for the warning about anti self-repair! Was debating replacing it myself to save using up a strike for more serious damage. I didn't see anything about that voiding the warranty though...
Dawson Ross -
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 120
30일 전: 512
전체 시간: 16,278
