주요 콘텐츠로 건너뛰기
DJI Phantom 3 Standard Remote Controller Joysticks Replacement
필요한 것
  1. DJI Phantom 3 Standard Remote Controller Joysticks Replacement, Joysticks: 1 단계, 이미지 2개 중 1개 DJI Phantom 3 Standard Remote Controller Joysticks Replacement, Joysticks: 1 단계, 이미지 2개 중 2개
    • Position the controller so the back is facing up and the joysticks are resting on the table.
    • Remove the four 11 mm screws that secure the back plate using a JIS #0 screwdriver.
    • Remove the back plate, being mindful of the wires still connected to the device.
  2. DJI Phantom 3 Standard Remote Controller Joysticks Replacement: 2 단계, 이미지 1개 중 1개
    • On the inside of the controller, remove the four 11 mm screws that cover the base housing of the joystick.
  3. DJI Phantom 3 Standard Remote Controller Joysticks Replacement: 3 단계, 이미지 3개 중 1개 DJI Phantom 3 Standard Remote Controller Joysticks Replacement: 3 단계, 이미지 3개 중 2개 DJI Phantom 3 Standard Remote Controller Joysticks Replacement: 3 단계, 이미지 3개 중 3개
    • Inside the base housing, remove the two 9 mm screws that secure the joystick brace piece on both the left and right side of the stick.
    • Remove the braces on the left and right sides of the joystick to reach the circuit board piece on the left.
    • Detach the circuit board piece.
  4. DJI Phantom 3 Standard Remote Controller Joysticks Replacement: 4 단계, 이미지 2개 중 1개 DJI Phantom 3 Standard Remote Controller Joysticks Replacement: 4 단계, 이미지 2개 중 2개
    • Separate the other circuit board piece from the joystick connection using a plastic spudger.
    • The circuit board is wired through glue. If the plastic spudger is unable to pry the glue off, use the metal spudger as a last resort.
    • Take the joystick module itself and remove the four 8 mm screws that connect the joystick to the housing.
    • Unscrew the thumb stick from the module if a replacement is not needed.
  5. DJI Phantom 3 Standard Remote Controller Joysticks Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the joystick.
결론
작성자
2다른 기여자 명과 함께
Maddie McCoy
회원 가입일: 09/04/24
238 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 7
전체 시간: 196
