소개
If you have a damaged or malfunctioning motor, this guide will lead you step by step on how to replace those motors. For this guide you will need a soldering iron.
필요한 것
Use your finger tips to pinch the damaged propeller.
Twist the propeller counterclockwise and pull up to remove.
Remove the two 4 mm screws using the JIS #000 bit.
Flip the metal bracket to the right and slide up.
Desolder the motor and LED wires on both sides of the board. For general soldering information, visit this Soldering Technique Guide.
다른 2명이 해당 안내서를 완성하였습니다.
