주요 콘텐츠로 건너뛰기
DOPO 10.1 Tablet Speaker Replacement
필요한 것
  1. DOPO 10.1 Tablet Speaker Replacement, Separating the Covers: 1 단계, 이미지 1/3 DOPO 10.1 Tablet Speaker Replacement, Separating the Covers: 1 단계, 이미지 2/3 DOPO 10.1 Tablet Speaker Replacement, Separating the Covers: 1 단계, 이미지 3/3
    • • Insert tool into crease between covers. First, insert one of the plastic tools between the front and back cover as shown. Next, twist the plastic tool until separation has occurred between the front and back of the tablet. Repeat this step until the user is able to fully separate the front and back covers.
  2. DOPO 10.1 Tablet Speaker Replacement, Locate the Speakers: 2 단계, 이미지 1/2 DOPO 10.1 Tablet Speaker Replacement, Locate the Speakers: 2 단계, 이미지 2/2
    • The speakers should be attached to the white cover of the tablet as shown. Follow the wires back to the mother board making sure to remove all tape attaching wires to cover along the way. This will free up the wires for easy maneuverability.
  3. DOPO 10.1 Tablet Speaker Replacement, Clearing the Pathway to Remove Speakers: 3 단계, 이미지 1/3 DOPO 10.1 Tablet Speaker Replacement, Clearing the Pathway to Remove Speakers: 3 단계, 이미지 2/3 DOPO 10.1 Tablet Speaker Replacement, Clearing the Pathway to Remove Speakers: 3 단계, 이미지 3/3
    • We will need to separate the battery from the panel slightly. This will allow for easier maneuverability to remove speakers. Do not separate the battery completely.
  4. DOPO 10.1 Tablet Speaker Replacement, Desoldering Speakers from Tablet Motherboard: 4 단계, 이미지 1/3 DOPO 10.1 Tablet Speaker Replacement, Desoldering Speakers from Tablet Motherboard: 4 단계, 이미지 2/3 DOPO 10.1 Tablet Speaker Replacement, Desoldering Speakers from Tablet Motherboard: 4 단계, 이미지 3/3
    • De-solder the red and black wires from the tablets motherboard. This will officially disconnect, and separate the defective speakers from the motherboard.
  5. DOPO 10.1 Tablet Speaker Replacement, Removing Speakers: 5 단계, 이미지 1/1
    • Remove defective speakers from their location in tablet.
결론
Kaitlyn Hayes
회원 가입일: 01/21/15
414 평판
안내서 4개 작성하였습니다
USF Tampa, Team 5-2, Brown Winter 2015 USF Tampa, Team 5-2, Brown Winter 2015 회원
USFT-BROWN-W15S5G2
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 915
