주요 콘텐츠로 건너뛰기
DR.J Professional HI-04 Speaker Replacement
필요한 것
  1. DR.J Professional HI-04 Speaker Replacement, Speaker: 1 단계, 이미지 1/3 DR.J Professional HI-04 Speaker Replacement, Speaker: 1 단계, 이미지 2/3 DR.J Professional HI-04 Speaker Replacement, Speaker: 1 단계, 이미지 3/3
    • Flip the projector so that the bottom is facing up.
    • Remove eight 10.0 mm screws from the back case with a Phillips #0 screwdriver.
    • The screws are set deep in the holes, so be careful not to drop them.
    • Remove two 20.0 mm screws with a Phillips #0 screwdriver.
  2. DR.J Professional HI-04 Speaker Replacement: 2 단계, 이미지 1/3 DR.J Professional HI-04 Speaker Replacement: 2 단계, 이미지 2/3 DR.J Professional HI-04 Speaker Replacement: 2 단계, 이미지 3/3
    • Flip the projector so it is upright.
    • Remove the top case of the projector.
    • The shell of the projector should lift up easily but is fragile, so be gentle while lifting.
    • The top case is connected to the motherboard by cables, so avoid yanking it off to prevent snapping the connectors or damaging components.
  3. DR.J Professional HI-04 Speaker Replacement: 3 단계, 이미지 1/2 DR.J Professional HI-04 Speaker Replacement: 3 단계, 이미지 2/2
    • Remove the three pieces of tape securing cables.
    • Keep the tape for reassembly.
  4. DR.J Professional HI-04 Speaker Replacement: 4 단계, 이미지 1/2 DR.J Professional HI-04 Speaker Replacement: 4 단계, 이미지 2/2
    • Use a Phillips #0 screwdriver to remove the four 15.0 mm screws from the motherboard.
    • Be sure to not drop the screws in the device as they can be difficult to recover.
  5. DR.J Professional HI-04 Speaker Replacement: 5 단계, 이미지 1/3 DR.J Professional HI-04 Speaker Replacement: 5 단계, 이미지 2/3 DR.J Professional HI-04 Speaker Replacement: 5 단계, 이미지 3/3
    • Squeeze the tab against the connector, and pull the connector straight from the socket to disconnect the speaker cable from the port.
    • The cable should come out easily so do not pull too hard.
  6. DR.J Professional HI-04 Speaker Replacement: 6 단계, 이미지 1/2 DR.J Professional HI-04 Speaker Replacement: 6 단계, 이미지 2/2
    • Use a Phillips #0 screwdriver to remove the three 15.0 mm screws from the black cover.
    • The screws are set deep in the holes, so be careful to not drop the screws, as they can be difficult to recover.
  7. DR.J Professional HI-04 Speaker Replacement: 7 단계, 이미지 1/2 DR.J Professional HI-04 Speaker Replacement: 7 단계, 이미지 2/2
    • Gently remove the black cover.
  8. DR.J Professional HI-04 Speaker Replacement: 8 단계, 이미지 1/2 DR.J Professional HI-04 Speaker Replacement: 8 단계, 이미지 2/2
    • Slide the back panel with the speaker up from the bottom case of the project.
  9. DR.J Professional HI-04 Speaker Replacement: 9 단계, 이미지 1/3 DR.J Professional HI-04 Speaker Replacement: 9 단계, 이미지 2/3 DR.J Professional HI-04 Speaker Replacement: 9 단계, 이미지 3/3
    • Use a Phillips #0 screwdriver to remove the two 10.0 mm screws that secure the speaker.
결론
Baron Dutra
회원 가입일: 11/01/23
825 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team 1-5, Petersen Fall 2023 UMass Dartmouth, Team 1-5, Petersen Fall 2023 회원
UMASSD-PETERSEN-F23S1G5
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 15
전체 시간: 78
