주요 콘텐츠로 건너뛰기
DROCON Ninja Camera Replacement
필요한 것
  1. DROCON Ninja Camera Replacement, Battery: 1 단계, 이미지 3개 중 1개 DROCON Ninja Camera Replacement, Battery: 1 단계, 이미지 3개 중 2개 DROCON Ninja Camera Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Make sure the drone is powered off before beginning the battery replacement.
    • To turn the drone off, press and hold the black button on the top of the drone until all lights are off.
    • Firmly grasp the battery tab between your thumb and index finger.
    • Pull the battery away from the drone's body
  2. DROCON Ninja Camera Replacement, Casing: 2 단계, 이미지 3개 중 1개 DROCON Ninja Camera Replacement, Casing: 2 단계, 이미지 3개 중 2개 DROCON Ninja Camera Replacement, Casing: 2 단계, 이미지 3개 중 3개
    • Using a Phillips #00 Screwdriver remove the eight 4mm screws on the bottom of the drone.
  3. DROCON Ninja Camera Replacement: 3 단계, 이미지 2개 중 1개 DROCON Ninja Camera Replacement: 3 단계, 이미지 2개 중 2개
    • Gently pull white casing away from the black bottom casing
  4. DROCON Ninja Camera Replacement: 4 단계, 이미지 3개 중 1개 DROCON Ninja Camera Replacement: 4 단계, 이미지 3개 중 2개 DROCON Ninja Camera Replacement: 4 단계, 이미지 3개 중 3개
    • Insert the opening tool under one of the black plastic connector slots that connects the circuit-board to the casing.
    • Gently pull the opening tool toward you to disconnect the circuit-board from the plastic casing.
  5. DROCON Ninja Camera Replacement, Camera: 5 단계, 이미지 3개 중 1개 DROCON Ninja Camera Replacement, Camera: 5 단계, 이미지 3개 중 2개 DROCON Ninja Camera Replacement, Camera: 5 단계, 이미지 3개 중 3개
    • Use a Phillips #00 screwdriver to remove the 5mm screws connecting the front two motor arms to the drone's body.
    • Use your fingers to gently pull the white plastic discs out of the motor arms.
  6. DROCON Ninja Camera Replacement: 6 단계, 이미지 2개 중 1개 DROCON Ninja Camera Replacement: 6 단계, 이미지 2개 중 2개
    • Grasp the motor arm and pull up and away from the drone's body.
    • Repeat this step for the other front motor arm.
  7. DROCON Ninja Camera Replacement: 7 단계, 이미지 3개 중 1개 DROCON Ninja Camera Replacement: 7 단계, 이미지 3개 중 2개 DROCON Ninja Camera Replacement: 7 단계, 이미지 3개 중 3개
    • Using the Phillips #00 screwdriver, remove the two 3mm screws on the control board.
  8. DROCON Ninja Camera Replacement: 8 단계, 이미지 3개 중 1개 DROCON Ninja Camera Replacement: 8 단계, 이미지 3개 중 2개 DROCON Ninja Camera Replacement: 8 단계, 이미지 3개 중 3개
    • Using the opening tool flip up the black plastic clamp that holds the camera wire to the circuit board.
    • Gently pull the camera out from the control board.
결론
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 9
전체 시간: 326
