주요 콘텐츠로 건너뛰기
DROCON Ninja Motor Replacement
필요한 것
  1. DROCON Ninja Motor Replacement, Battery: 1 단계, 이미지 3개 중 1개 DROCON Ninja Motor Replacement, Battery: 1 단계, 이미지 3개 중 2개 DROCON Ninja Motor Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Make sure the drone is powered off before beginning the battery replacement.
    • To turn the drone off, press and hold the black button on the top of the drone until all lights are off.
    • Firmly grasp the battery tab between your thumb and index finger.
    • Pull the battery away from the drone's body
  2. DROCON Ninja Motor Replacement, Casing: 2 단계, 이미지 3개 중 1개 DROCON Ninja Motor Replacement, Casing: 2 단계, 이미지 3개 중 2개 DROCON Ninja Motor Replacement, Casing: 2 단계, 이미지 3개 중 3개
    • Using a Phillips #00 Screwdriver remove the eight 4mm screws on the bottom of the drone.
  3. DROCON Ninja Motor Replacement: 3 단계, 이미지 2개 중 1개 DROCON Ninja Motor Replacement: 3 단계, 이미지 2개 중 2개
    • Gently pull white casing away from the black bottom casing
  4. DROCON Ninja Motor Replacement: 4 단계, 이미지 3개 중 1개 DROCON Ninja Motor Replacement: 4 단계, 이미지 3개 중 2개 DROCON Ninja Motor Replacement: 4 단계, 이미지 3개 중 3개
    • Insert the opening tool under one of the black plastic connector slots that connects the circuit-board to the casing.
    • Gently pull the opening tool toward you to disconnect the circuit-board from the plastic casing.
  5. DROCON Ninja Motor Replacement, Motor: 5 단계, 이미지 2개 중 1개 DROCON Ninja Motor Replacement, Motor: 5 단계, 이미지 2개 중 2개
    • Firmly grasp the blade guard from the bottom of the drone
    • Pull the blade guard straight down away from motor.
  6. DROCON Ninja Motor Replacement: 6 단계, 이미지 3개 중 1개 DROCON Ninja Motor Replacement: 6 단계, 이미지 3개 중 2개 DROCON Ninja Motor Replacement: 6 단계, 이미지 3개 중 3개
    • Grasp the center of the propeller that needs to be replaced.
    • Pull the propeller directly up and away from the motor.
  7. DROCON Ninja Motor Replacement: 7 단계, 이미지 3개 중 1개 DROCON Ninja Motor Replacement: 7 단계, 이미지 3개 중 2개 DROCON Ninja Motor Replacement: 7 단계, 이미지 3개 중 3개
    • Use a Phillips #00 screwdriver to remove the two 5mm screws connecting the motor arm to the drone's body.
    • Use your fingers to gently pull the white plastic disc out of the motor arm.
  8. DROCON Ninja Motor Replacement: 8 단계, 이미지 3개 중 1개 DROCON Ninja Motor Replacement: 8 단계, 이미지 3개 중 2개 DROCON Ninja Motor Replacement: 8 단계, 이미지 3개 중 3개
    • Grasp the motor arm and pull up and away from the drone's body.
  9. DROCON Ninja Motor Replacement: 9 단계, 이미지 3개 중 1개 DROCON Ninja Motor Replacement: 9 단계, 이미지 3개 중 2개 DROCON Ninja Motor Replacement: 9 단계, 이미지 3개 중 3개
    • Use a Phillips #00 screwdriver to remove the three 4mm screws on the plate of the motor arm.
    • Using your fingers, pull apart the top and bottom pieces of the casing.
  10. DROCON Ninja Motor Replacement: 10 단계, 이미지 3개 중 1개 DROCON Ninja Motor Replacement: 10 단계, 이미지 3개 중 2개 DROCON Ninja Motor Replacement: 10 단계, 이미지 3개 중 3개
    • Use the opening tool to remove the small circuit board from the motor arm.
  11. DROCON Ninja Motor Replacement: 11 단계, 이미지 3개 중 1개 DROCON Ninja Motor Replacement: 11 단계, 이미지 3개 중 2개 DROCON Ninja Motor Replacement: 11 단계, 이미지 3개 중 3개
    • Use a pair of pliers to remove the motor by pulling up and away from the propeller arm.
결론
다른 2명이 해당 안내서를 완성하였습니다.
1가이드 댓글
I’ve got the motor out. Thank you! Now to find a suitable replacement. Do you know the specs of the motor or a source for a working one?
Tinkerer - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 23
전체 시간: 1,042
