주요 콘텐츠로 건너뛰기
DROCON Ninja Propeller Replacement
  1. DROCON Ninja Propeller Replacement, Battery: 1 단계, 이미지 3개 중 1개 DROCON Ninja Propeller Replacement, Battery: 1 단계, 이미지 3개 중 2개 DROCON Ninja Propeller Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Make sure the drone is powered off before beginning the battery replacement.
    • To turn the drone off, press and hold the black button on the top of the drone until all lights are off.
    • Firmly grasp the battery tab between your thumb and index finger.
    • Pull the battery away from the drone's body
  2. DROCON Ninja Propeller Replacement, Propeller: 2 단계, 이미지 2개 중 1개 DROCON Ninja Propeller Replacement, Propeller: 2 단계, 이미지 2개 중 2개
    • Firmly grasp the blade guard from the bottom of the drone
    • Pull the blade guard straight down away from motor.
  3. DROCON Ninja Propeller Replacement: 3 단계, 이미지 3개 중 1개 DROCON Ninja Propeller Replacement: 3 단계, 이미지 3개 중 2개 DROCON Ninja Propeller Replacement: 3 단계, 이미지 3개 중 3개
    • Take note of the letter printed on the bottom of the propeller. Make sure the replacement propeller has the same letter.
    • Grasp the center of the propeller that needs to be replaced.
    • Pull the propeller directly up and away from the motor.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Taylor Ullmann
회원 가입일: 01/24/20
474 평판
안내서 3개를 작성함
4가이드 댓글
can we buy an extra battery?
Orlay Gutierrez - 답글
can we buy an extra battery for the roconDC-014
hi i have the red & bleu drocon dc-014 & wold like to order the white drocon dc-014 white drone or white body cover
tank you! & happy new year!!!
claude demers - 답글
i both drocon dc-014 blue & red wold like by the white drocon dc-014 or uper casse
claude demers - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 23
전체 시간: 2,020
