주요 콘텐츠로 건너뛰기
David Clark Over-Ear Headphones Right Dome Replacement
필요한 것
  1. David Clark Over-Ear Headphones Right Dome Replacement, Right Dome: 1 단계, 이미지 1/3 David Clark Over-Ear Headphones Right Dome Replacement, Right Dome: 1 단계, 이미지 2/3 David Clark Over-Ear Headphones Right Dome Replacement, Right Dome: 1 단계, 이미지 3/3
    • This is the headset that will get both domes replaced. This guide is for the right side dome only.
    • Missing retainer pins are obvious.
    • This is where the retainer rings would be normally sitting to hold the dome to the stirrup
    • I always wonder who owned the equipment before and what the story is behind those initials
  2. David Clark Over-Ear Headphones Right Dome Replacement: 2 단계, 이미지 1/3 David Clark Over-Ear Headphones Right Dome Replacement: 2 단계, 이미지 2/3 David Clark Over-Ear Headphones Right Dome Replacement: 2 단계, 이미지 3/3
    • Since the retainers are missing, just pulling up on the stirrup
    • will release the dome.
    • Same thing on the other side
  3. David Clark Over-Ear Headphones Right Dome Replacement: 3 단계, 이미지 1/3 David Clark Over-Ear Headphones Right Dome Replacement: 3 단계, 이미지 2/3 David Clark Over-Ear Headphones Right Dome Replacement: 3 단계, 이미지 3/3
    • Here is the dome free of the stirrup.
    • The earseal is in decent condition. The filter (foam) shows plenty of wear and markings.
    • The earseal is held on by a groove in the dome. Simply pulling it off will release it.
  4. David Clark Over-Ear Headphones Right Dome Replacement: 4 단계, 이미지 1/3 David Clark Over-Ear Headphones Right Dome Replacement: 4 단계, 이미지 2/3 David Clark Over-Ear Headphones Right Dome Replacement: 4 단계, 이미지 3/3
    • Earseal removed from dome, filter visible.
    • Next remove the filter (foam) to visualize the speaker.
    • Remove the next filter (foam) that is layered around the speaker
  5. David Clark Over-Ear Headphones Right Dome Replacement: 5 단계, 이미지 1/3 David Clark Over-Ear Headphones Right Dome Replacement: 5 단계, 이미지 2/3 David Clark Over-Ear Headphones Right Dome Replacement: 5 단계, 이미지 3/3
    • Filter removed, and another filter is visible around the speaker. The original headset will have three filters
    • One more filter under the speaker that needs to be removed.
    • The two screws that hold the speaker to the dome are clearly visible
  6. David Clark Over-Ear Headphones Right Dome Replacement: 6 단계, 이미지 1/3 David Clark Over-Ear Headphones Right Dome Replacement: 6 단계, 이미지 2/3 David Clark Over-Ear Headphones Right Dome Replacement: 6 단계, 이미지 3/3
    • These are the two slotted screws that hold the speaker to the dome
    • Remove those with a flathead screw driver
    • Once the two screws are loose, lift the speaker out of the dome.
  7. David Clark Over-Ear Headphones Right Dome Replacement: 7 단계, 이미지 1/3 David Clark Over-Ear Headphones Right Dome Replacement: 7 단계, 이미지 2/3 David Clark Over-Ear Headphones Right Dome Replacement: 7 단계, 이미지 3/3
    • Flip the speaker out of the dome to remove the last filter.
    • With the speaker and the filter removed, damage to a standoff for the speaker becomes evident
    • The speaker wires are held in place by two slotted screws
  8. David Clark Over-Ear Headphones Right Dome Replacement: 8 단계, 이미지 1/3 David Clark Over-Ear Headphones Right Dome Replacement: 8 단계, 이미지 2/3 David Clark Over-Ear Headphones Right Dome Replacement: 8 단계, 이미지 3/3
    • Loosen the two screws to remove the speaker
    • Pull the speaker wire (overhead cord) to the inside of the dome to free the cord clip
    • Using a pair of combination pliers, squeeze the two tabs of the cord clip
  9. David Clark Over-Ear Headphones Right Dome Replacement: 9 단계, 이미지 1/3 David Clark Over-Ear Headphones Right Dome Replacement: 9 단계, 이미지 2/3 David Clark Over-Ear Headphones Right Dome Replacement: 9 단계, 이미지 3/3
    • This will open the cord clip
    • Remove the cord clip
    • Pull the speaker wire (overhead cord) out of the dome.
  10. David Clark Over-Ear Headphones Right Dome Replacement: 10 단계, 이미지 1/3 David Clark Over-Ear Headphones Right Dome Replacement: 10 단계, 이미지 2/3 David Clark Over-Ear Headphones Right Dome Replacement: 10 단계, 이미지 3/3
    • Here is the damage of the speaker standoff
    • Remove the rubber grommet from the speaker cable opening by using a jewelers screw driver. Gently use the screw driver to push the lip out of the opening.
    • Removed rubber grommet.
  11. David Clark Over-Ear Headphones Right Dome Replacement: 11 단계, 이미지 1/1
    • Here is the old dome ready to be replaced with a new one.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
oldturkey03
회원 가입일: 09/29/10
784,147 평판
안내서 119개 작성하였습니다
Global Fixers Global Fixers 회원
Community
33 회원들
안내서 556개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 11
30일 전: 20
전체 시간: 1,811
