주요 콘텐츠로 건너뛰기
Dell Adamo XPS Solid State Drive Replacement
필요한 것
  1. 주의: 1-2 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
    • Turn off the laptop before doing anything to the laptop.
    • Then turn the laptop around on its back.
    • On the back of the computer there is a latch that you have to slide and hold in order to remove the battery.
    • Then you have to push the computer battery towards the computer and rotate upwards.
    • Finally lift the battery out of the computer.
  2. 주의: 3-9 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
    • Turn the computer around and remove the eighteen screws on the base cover.
    • The screws that secure the base cover are of different sizes. Note the location and size of the screws as you remove them so that you can replace them correctly
    • You aren't actually taking apart the display but only opening it up to gain access to the palm rest panel and keyboard.
    • Use your fingers to ease the palm rest assembly from the computer.
    • Pull on the plastic tab on top of the cables to avoid damaging the connectors.
    • Exercise extreme care while lifting the palm rest assembly to avoid damaging the function key cable.
    • Lift the palm rest assembly to access the function key cable.
    • To prevent damage to the function key cable, do not disconnect the function key cable from the palm rest.
    • Disconnect the function key cable from the connector on the system board.
    • Lift the connector latch that secures the touch pad cable to the touch pad connector and remove the cable.
    • To prevent damage to the display hinges, ensure that you do not adjust the angle between the display and the computer base after removing the palm rest assembly.
    • Lift the palm rest assembly off the computer base.
    • Remove the screw that secures the solid state drive to the computer base.
    • Slide and lift the solid state drive to disconnect it from the connector on the right daughter board.
    • When the solid state drive is not in the computer, store it in protective antistatic packaging.
    • Get the new drive from the packaging .
    • Save the original packaging for storing or shipping the solid state drive.
    • If your existing solid sate drive was shipped with mylar cover, replace the mylar cover on the new drive.
    • Push the solid state drive until it is fully connected to the connector on the right daughter board.
    • Replace the screw that secures the solid state drive to the computer base.
    • Before turning on the computer, replace all screws and ensure that no stray screws remain inside the computer. Failure to do so result in damage to the computer.
    • Install the operating system for your computer, as needed.
    • Install the drivers and utilities for your computer, as needed.
결론
Christopher Melo-Pelaez
회원 가입일: 10/27/17
1,921 평판
안내서 9개 작성하였습니다
RampUP America, Inc. RampUP America, Inc. 회원
Community
42 회원들
안내서 1,985개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 10
전체 시간: 91
