주요 콘텐츠로 건너뛰기
Dell Alienware 18 Battery Pack Replacement
필요한 것
  1. Dell Alienware 18 Battery Pack Replacement, Before You Begin: 1 단계, 이미지 1/1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin.
  2. Dell Alienware 18 Battery Pack Replacement, Remove the base cover screws: 2 단계, 이미지 1/1
    • Use a Phillips screwdriver to remove the three screws securing the base cover.
  3. Dell Alienware 18 Battery Pack Replacement, Slide the Cover: 3 단계, 이미지 1/1
    • Slide the base cover towards the rear of the computer and lift it off the computer base.
  4. Dell Alienware 18 Battery Pack Replacement, Prelude: 4 단계, 이미지 1/1
  5. Dell Alienware 18 Battery Pack Replacement, Remove the battery screws: 5 단계, 이미지 1/1
    • Use a Phillips screwdriver to remove the two screws securing the battery to the computer base.
  6. Dell Alienware 18 Battery Pack Replacement, Disconnect the battery cable: 6 단계, 이미지 1/1
    • Disconnect the battery cable from its connector by pulling it straight up from its socket.
  7. Dell Alienware 18 Battery Pack Replacement, Remove the battery: 7 단계, 이미지 1/1
    • Remove the battery from its recess.
결론
For optimal performance, after completing this guide, calibrate your newly installed battery.
다른 한 분이 해당 안내서를 완성하였습니다.
darrius
회원 가입일: 03/26/18
5,213 평판
안내서 30개 작성하였습니다
RampUP America, Inc. RampUP America, Inc. 회원
Community
42 회원들
안내서 1,985개 작성하였습니다
댓글 한 개
This is the wrong computer being displayed here.
Tru-B -DaT - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 15
전체 시간: 1,200
