주요 콘텐츠로 건너뛰기
Dell Chromebook 5190 Motherboard Replacement
필요한 것
  1. Dell Chromebook 5190 Motherboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Before starting, please make sure you have disconnected and removed all devices populating the laptop's ports.
    • Remove the nine M2.5x7.5 screws located on the bottom side of the laptop.
  2. Dell Chromebook 5190 Motherboard Replacement: 2 단계, 이미지 3개 중 1개 Dell Chromebook 5190 Motherboard Replacement: 2 단계, 이미지 3개 중 2개 Dell Chromebook 5190 Motherboard Replacement: 2 단계, 이미지 3개 중 3개
    • Be cautious, the following instructions are to prevent cracking the base cover.
    • With the opening tool, pry open the upper left corner by the laptop hinge.
    • With the opening tool, pry open the upper right corner by the laptop hinge.
    • Lift off base cover.
  3. Dell Chromebook 5190 Motherboard Replacement: 3 단계, 이미지 2개 중 1개 Dell Chromebook 5190 Motherboard Replacement: 3 단계, 이미지 2개 중 2개
    • Unscrew and remove the M2x3 screw holding the silver metal brackets labeled "Battery Bracket" located on the top left side of the battery.
    • Unscrew and remove the M2x3 screw holding the silver metal brackets labeled "Battery Bracket" located on the top right side of the battery.
  4. Dell Chromebook 5190 Motherboard Replacement: 4 단계, 이미지 2개 중 1개 Dell Chromebook 5190 Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the clear adhesive tape on the system board from the battery cable from where it's seated above the battery.
    • Pull out the keyboard cable toward you to disconnect it.
  5. Dell Chromebook 5190 Motherboard Replacement: 5 단계, 이미지 2개 중 1개 Dell Chromebook 5190 Motherboard Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the black adhesive tape on the system board from the battery cable.
    • Dismount the cable from where it's seated above the battery.
  6. Dell Chromebook 5190 Motherboard Replacement: 6 단계, 이미지 3개 중 1개 Dell Chromebook 5190 Motherboard Replacement: 6 단계, 이미지 3개 중 2개 Dell Chromebook 5190 Motherboard Replacement: 6 단계, 이미지 3개 중 3개
    • Unscrew and remove the four M2x3 screws on each corner of the battery.
    • Dismount the battery.
  7. Dell Chromebook 5190 Motherboard Replacement, Motherboard: 7 단계, 이미지 2개 중 1개 Dell Chromebook 5190 Motherboard Replacement, Motherboard: 7 단계, 이미지 2개 중 2개
    • To disconnect the first purple I/O cable, first lift the purple tab upwards.
    • Next, pull the purple tab away from the motherboard.
  8. Dell Chromebook 5190 Motherboard Replacement: 8 단계, 이미지 2개 중 1개 Dell Chromebook 5190 Motherboard Replacement: 8 단계, 이미지 2개 중 2개
    • To disconnect the second purple I/O cable, first lift the purple tab upwards.
  9. Dell Chromebook 5190 Motherboard Replacement: 9 단계, 이미지 2개 중 1개 Dell Chromebook 5190 Motherboard Replacement: 9 단계, 이미지 2개 중 2개
    • To disconnect the touchpad cable, first lift the purple tab upwards.
  10. Dell Chromebook 5190 Motherboard Replacement: 10 단계, 이미지 2개 중 1개 Dell Chromebook 5190 Motherboard Replacement: 10 단계, 이미지 2개 중 2개
    • Push downwards on the black tabs located on both side of the motherboard connector.
    • Disconnect the keyboard cable.
  11. Dell Chromebook 5190 Motherboard Replacement: 11 단계, 이미지 1개 중 1개
    • Disconnect the speaker cable by pulling it from the motherboard connector.
  12. Dell Chromebook 5190 Motherboard Replacement: 12 단계, 이미지 3개 중 1개 Dell Chromebook 5190 Motherboard Replacement: 12 단계, 이미지 3개 중 2개 Dell Chromebook 5190 Motherboard Replacement: 12 단계, 이미지 3개 중 3개
    • Screw the single (M2x4) screw on the eDP bracket.
    • Unhook the eDP bracket.
    • Lift the eDP bracket off.
  13. Dell Chromebook 5190 Motherboard Replacement: 13 단계, 이미지 2개 중 1개 Dell Chromebook 5190 Motherboard Replacement: 13 단계, 이미지 2개 중 2개
    • Remove clear adhesive tape off the motherboard connector.
    • Lift the black tab located on the display connector.
  14. Dell Chromebook 5190 Motherboard Replacement: 14 단계, 이미지 2개 중 1개 Dell Chromebook 5190 Motherboard Replacement: 14 단계, 이미지 2개 중 2개
    • Disconnect the display cable from the motherboard connector.
    • Remove the adhesive tape from the motherboard.
  15. Dell Chromebook 5190 Motherboard Replacement: 15 단계, 이미지 3개 중 1개 Dell Chromebook 5190 Motherboard Replacement: 15 단계, 이미지 3개 중 2개 Dell Chromebook 5190 Motherboard Replacement: 15 단계, 이미지 3개 중 3개
    • Unscrew the single (M2x4) screw from the motherboard bracket.
    • Unhook the motherboard bracket.
    • Lift the motherboard bracket.
  16. Dell Chromebook 5190 Motherboard Replacement: 16 단계, 이미지 3개 중 1개 Dell Chromebook 5190 Motherboard Replacement: 16 단계, 이미지 3개 중 2개 Dell Chromebook 5190 Motherboard Replacement: 16 단계, 이미지 3개 중 3개
    • Unscrew 3 (M2x3) screws on the motherboard.
    • Unhook the motherboard by placing it at an angle.
    • Lift the motherboard.
결론
작성자
2다른 기여자 명과 함께
Denise Cano
회원 가입일: 02/10/22
617 평판
안내서 4개를 작성함
Gateway, Team 1-3, Pee Spring 2022 Gateway, Team 1-3, Pee Spring 2022 회원
GCC-PEE-S22S1G3
3 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 16
전체 시간: 679
