주요 콘텐츠로 건너뛰기
Dell Chromebook 5190 WLAN Card Replacement
필요한 것
  1. Dell Chromebook 5190 WLAN Card Replacement, Battery: 1 단계, 이미지 1/1
    • Before starting, please make sure you have disconnected and removed all devices populating the laptop's ports.
    • Remove the nine M2.5x7.5 screws located on the bottom side of the laptop.
  2. Dell Chromebook 5190 WLAN Card Replacement: 2 단계, 이미지 1/3 Dell Chromebook 5190 WLAN Card Replacement: 2 단계, 이미지 2/3 Dell Chromebook 5190 WLAN Card Replacement: 2 단계, 이미지 3/3
    • Be cautious, the following instructions are to prevent cracking the base cover.
    • With the opening tool, pry open the upper left corner by the laptop hinge.
    • With the opening tool, pry open the upper right corner by the laptop hinge.
    • Lift off base cover.
  3. Dell Chromebook 5190 WLAN Card Replacement: 3 단계, 이미지 1/2 Dell Chromebook 5190 WLAN Card Replacement: 3 단계, 이미지 2/2
    • Unscrew and remove the M2x3 screw holding the silver metal brackets labeled "Battery Bracket" located on the top left side of the battery.
    • Unscrew and remove the M2x3 screw holding the silver metal brackets labeled "Battery Bracket" located on the top right side of the battery.
  4. Dell Chromebook 5190 WLAN Card Replacement: 4 단계, 이미지 1/2 Dell Chromebook 5190 WLAN Card Replacement: 4 단계, 이미지 2/2
    • Remove the clear adhesive tape on the system board from the battery cable from where it's seated above the battery.
    • Pull out the keyboard cable toward you to disconnect it.
  5. Dell Chromebook 5190 WLAN Card Replacement: 5 단계, 이미지 1/2 Dell Chromebook 5190 WLAN Card Replacement: 5 단계, 이미지 2/2
    • Remove the black adhesive tape on the system board from the battery cable.
    • Dismount the cable from where it's seated above the battery.
  6. Dell Chromebook 5190 WLAN Card Replacement: 6 단계, 이미지 1/3 Dell Chromebook 5190 WLAN Card Replacement: 6 단계, 이미지 2/3 Dell Chromebook 5190 WLAN Card Replacement: 6 단계, 이미지 3/3
    • Unscrew and remove the four M2x3 screws on each corner of the battery.
    • Dismount the battery.
  7. Dell Chromebook 5190 WLAN Card Replacement, WLAN Card: 7 단계, 이미지 1/2 Dell Chromebook 5190 WLAN Card Replacement, WLAN Card: 7 단계, 이미지 2/2
    • Unscrew and remove the M2x3 screw.
    • Remove the metal bracket.
  8. Dell Chromebook 5190 WLAN Card Replacement: 8 단계, 이미지 1/1
    • Remove WLAN antennas.
  9. Dell Chromebook 5190 WLAN Card Replacement: 9 단계, 이미지 1/1
    • Slide the WLAN card away from the motherboard.
결론
Brian
회원 가입일: 02/10/22
97 평판
안내서 1개 작성함
Gateway, Team 1-3, Pee Spring 2022 Gateway, Team 1-3, Pee Spring 2022 회원
GCC-PEE-S22S1G3
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 11
전체 시간: 120
