주요 콘텐츠로 건너뛰기
Dell Inspiron 11-3162 Battery Replacement
필요한 것
  1. Dell Inspiron 11-3162 Battery Replacement, Back Cover Removal: 1 단계, 이미지 1/2 Dell Inspiron 11-3162 Battery Replacement, Back Cover Removal: 1 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use tweezers to pry and remove the center screw cover on the back cover.
  2. Dell Inspiron 11-3162 Battery Replacement: 2 단계, 이미지 1/2 Dell Inspiron 11-3162 Battery Replacement: 2 단계, 이미지 2/2
    • Use a Phillips screwdriver to unscrew the nine 6.8 mm screws securing the back cover.
  3. Dell Inspiron 11-3162 Battery Replacement: 3 단계, 이미지 1/1
    • Use a spudger to pry around the base edges of the back cover to loosen it from the laptop.
    • Do not fully remove the cover, as it is still attached to the laptop with cables.
  4. Dell Inspiron 11-3162 Battery Replacement: 4 단계, 이미지 1/3 Dell Inspiron 11-3162 Battery Replacement: 4 단계, 이미지 2/3 Dell Inspiron 11-3162 Battery Replacement: 4 단계, 이미지 3/3
    • If you are only replacing the battery, you can skip this step. Be careful not to strain the still-connected cable as you work.
    • Unlock the wide ZIF connector securing the flex cable.
    • To unlock a ZIF connector, use the tip of a spudger or your fingernail to flip up the small, hinged locking flap.
    • Pull the ribbon cable outwards to disconnect the back cover from the motherboard.
  5. Dell Inspiron 11-3162 Battery Replacement, Battery: 5 단계, 이미지 1/2 Dell Inspiron 11-3162 Battery Replacement, Battery: 5 단계, 이미지 2/2
    • Use a Phillips screwdriver to unscrew the three 4 mm screws securing the battery.
  6. Dell Inspiron 11-3162 Battery Replacement: 6 단계, 이미지 1/3 Dell Inspiron 11-3162 Battery Replacement: 6 단계, 이미지 2/3 Dell Inspiron 11-3162 Battery Replacement: 6 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Use your fingers (or a set of tweezers) to disconnect the battery cable from the motherboard by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
    • Lift and remove the battery from its recess.
결론
For optimal performance, after completing this guide, calibrate your newly installed battery.
다른 6명이 해당 안내서를 완성하였습니다.
Dominic DeLong
회원 가입일: 09/29/16
775 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 26
전체 시간: 3,075
