소개
This guide will show you how to replace the battery of the Dell Inspiron 11-3168. Before starting, make sure both the laptop AC adapter and battery are disconnected prior to replacing any part or component.
필요한 것
Using a Phillips #00 screwdriver, remove all nine 7.5mm screws from the bottom case of the laptop.
For optimal performance, after completing this guide, calibrate your newly installed battery.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 2개
Well done with the instructions. AND I just noticed you attend - attended a school in El Dorado? I grew up in Pine Bluff. Your presentation was a big help to me.
Your are welcome Phillip. I am glad you found that repair guide to be helpful.
