주요 콘텐츠로 건너뛰기
Dell Inspiron 11-3168 Battery Replacement
필요한 것
  1. Dell Inspiron 11-3168 Battery Replacement, Battery: 1 단계, 이미지 1/2 Dell Inspiron 11-3168 Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Using a Phillips #00 screwdriver, remove all nine 7.5mm screws from the bottom case of the laptop.
  2. Dell Inspiron 11-3168 Battery Replacement: 2 단계, 이미지 1/3 Dell Inspiron 11-3168 Battery Replacement: 2 단계, 이미지 2/3 Dell Inspiron 11-3168 Battery Replacement: 2 단계, 이미지 3/3
    • Remove the bottom case of the laptop by gently prying along the seam with a plastic opening tool.
  3. Dell Inspiron 11-3168 Battery Replacement: 3 단계, 이미지 1/2 Dell Inspiron 11-3168 Battery Replacement: 3 단계, 이미지 2/2
    • Remove the one 7.5mm screw that is holding the battery in place.
  4. Dell Inspiron 11-3168 Battery Replacement: 4 단계, 이미지 1/2 Dell Inspiron 11-3168 Battery Replacement: 4 단계, 이미지 2/2
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  5. Dell Inspiron 11-3168 Battery Replacement: 5 단계, 이미지 1/3 Dell Inspiron 11-3168 Battery Replacement: 5 단계, 이미지 2/3 Dell Inspiron 11-3168 Battery Replacement: 5 단계, 이미지 3/3
    • Remove the battery.
결론
For optimal performance, after completing this guide, calibrate your newly installed battery.
다른 4명이 해당 안내서를 완성하였습니다.
Tyson Pace
회원 가입일: 01/17/19
464 평판
안내서 3개 작성하였습니다
댓글 2개
Well done with the instructions. AND I just noticed you attend - attended a school in El Dorado? I grew up in Pine Bluff. Your presentation was a big help to me.
Phillip Dennis - 답글
Your are welcome Phillip. I am glad you found that repair guide to be helpful.
Matthew Roomsburg - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 16
전체 시간: 936
