주요 콘텐츠로 건너뛰기
Dell Inspiron 13-5368 Audio Jack Replacement
필요한 것
  1. Dell Inspiron 13-5368 Audio Jack Replacement, 3.5 mm Audio Jack: 1 단계, 이미지 1/1
    • Use a Phillips #0 screwdriver to remove the 9 6mm screws securing the back plate of the laptop.
  2. Dell Inspiron 13-5368 Audio Jack Replacement: 2 단계, 이미지 1/1
    • Use a prying tool to remove the back plate.
  3. Dell Inspiron 13-5368 Audio Jack Replacement: 3 단계, 이미지 1/1
    • Use a Phillips #0 screwdriver to remove the three 3 mm screws holding the battery in place.
  4. Dell Inspiron 13-5368 Audio Jack Replacement: 4 단계, 이미지 1/1
    • Disconnect the cable connecting the battery to the motherboard, and then remove the battery.
  5. Dell Inspiron 13-5368 Audio Jack Replacement: 5 단계, 이미지 1/2 Dell Inspiron 13-5368 Audio Jack Replacement: 5 단계, 이미지 2/2
    • Using the Phillips #0 screwdriver, unscrew the 4 heatsink screws.
    • Remove the heatsink assembly.
  6. Dell Inspiron 13-5368 Audio Jack Replacement: 6 단계, 이미지 1/1
    • Using the Phillips #0, unscrew two 3mm screws holding the fan in place and disconnect the cable connecting it to the motherboard. There is an adhesive tab holding the hard drive cable in place up against the fan; remove this as well.
  7. Dell Inspiron 13-5368 Audio Jack Replacement: 7 단계, 이미지 1/3 Dell Inspiron 13-5368 Audio Jack Replacement: 7 단계, 이미지 2/3 Dell Inspiron 13-5368 Audio Jack Replacement: 7 단계, 이미지 3/3
    • Disconnect the following cables that connect to the motherboard: the Touchscreen, Display, and the speaker cable.
  8. Dell Inspiron 13-5368 Audio Jack Replacement: 8 단계, 이미지 1/3 Dell Inspiron 13-5368 Audio Jack Replacement: 8 단계, 이미지 2/3 Dell Inspiron 13-5368 Audio Jack Replacement: 8 단계, 이미지 3/3
    • Disconnect the following cables that connect to the motherboard: hard drive cable and touchpad cable.
  9. Dell Inspiron 13-5368 Audio Jack Replacement: 9 단계, 이미지 1/1
    • Using the Phillips #0 screwdriver, remove the three 2mm screws holding the motherboard in place. Once done, carefully lift the motherboard out.
  10. Dell Inspiron 13-5368 Audio Jack Replacement: 10 단계, 이미지 1/1
    • Flip the motherboard over and, using a soldering iron, apply heat to the 7 solder points of the audio jack. Carefully pull the audio jack out from below.
    • For more tips on soldering, please visit the How to Solder and Desolder Connections guide.
결론
Ian Zahar
회원 가입일: 11/10/18
208 평판
안내서 1개 작성함
IUPUI, Team S4-G4, Wilson Fall 2018 IUPUI, Team S4-G4, Wilson Fall 2018 회원
IUPUI-WILSON-F18S4G4
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 37
전체 시간: 1,976
