주요 콘텐츠로 건너뛰기
Dell Inspiron 13-5368 Battery Replacement
필요한 것
  1. Dell Inspiron 13-5368 Battery Replacement, Battery: 1 단계, 이미지 1/2 Dell Inspiron 13-5368 Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Remove the nine 6mm Phillips #0 screws that secure the back cover of the laptop.
  2. Dell Inspiron 13-5368 Battery Replacement: 2 단계, 이미지 1/2 Dell Inspiron 13-5368 Battery Replacement: 2 단계, 이미지 2/2
    • Use a spudger to pry up and remove the back cover.
  3. Dell Inspiron 13-5368 Battery Replacement: 3 단계, 이미지 1/1
    • Remove the four 3mm Phillips #0 screws at the corners of the battery that secure it to the laptop.
  4. Dell Inspiron 13-5368 Battery Replacement: 4 단계, 이미지 1/1
    • Pull the battery cable's black tab towards the battery to disconnect it from the motherboard.
    • Pull the tab parallel to the motherboard, not straight up.
  5. Dell Inspiron 13-5368 Battery Replacement: 5 단계, 이미지 1/2 Dell Inspiron 13-5368 Battery Replacement: 5 단계, 이미지 2/2
    • Remove the battery.
결론
For optimal performance, after completing this guide, calibrate your newly installed battery.
다른 14명이 해당 안내서를 완성하였습니다.
Matt Sugrim
회원 가입일: 09/27/17
1,042 평판
안내서 6개 작성하였습니다
USF Tampa, Team S14-G6, Boczar Fall 2017 USF Tampa, Team S14-G6, Boczar Fall 2017 회원
USFT-BOCZAR-F17S14G6
4 회원들
안내서 13개 작성하였습니다
댓글 3개
Awesome, very user friendly instructions. Was not looking forward to taking to computer repair store to replace internal battery. Thank you so much for these instructions.
rdcath - 답글
The new battery replacement does not come with a cable to attach to the motherboard. How can I use the cable from the old battery?
BilboBaggins314 - 답글
I have this same question^. Can I reuse the cable from the old battery?
Gloria Kolyabin -
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 34
30일 전: 154
전체 시간: 24,789
