주요 콘텐츠로 건너뛰기
Dell Inspiron 13-7347 Display Assembly Replacement
필요한 것
  1. Dell Inspiron 13-7347 Display Assembly Replacement, Battery: 1 단계, 이미지 1/3 Dell Inspiron 13-7347 Display Assembly Replacement, Battery: 1 단계, 이미지 2/3 Dell Inspiron 13-7347 Display Assembly Replacement, Battery: 1 단계, 이미지 3/3
    • Flip the device over, so that the back is facing up.
    • Remove the ten, 7 mm, Phillips #1 screws on the back of your Dell Inspiron 13-7347.
    • Use the suction cup to lift off the back case.
  2. Dell Inspiron 13-7347 Display Assembly Replacement: 2 단계, 이미지 1/3 Dell Inspiron 13-7347 Display Assembly Replacement: 2 단계, 이미지 2/3 Dell Inspiron 13-7347 Display Assembly Replacement: 2 단계, 이미지 3/3
    • Remove the three 4 mm JIS #00 screws that secure the battery to the device.
  3. Dell Inspiron 13-7347 Display Assembly Replacement: 3 단계, 이미지 1/3 Dell Inspiron 13-7347 Display Assembly Replacement: 3 단계, 이미지 2/3 Dell Inspiron 13-7347 Display Assembly Replacement: 3 단계, 이미지 3/3
    • Unplug the flat connector that is connected to the battery.
  4. Dell Inspiron 13-7347 Display Assembly Replacement: 4 단계, 이미지 1/3 Dell Inspiron 13-7347 Display Assembly Replacement: 4 단계, 이미지 2/3 Dell Inspiron 13-7347 Display Assembly Replacement: 4 단계, 이미지 3/3
    • Lift the battery steadily from the device.
    • Tilt the battery upward while removing.
  5. Dell Inspiron 13-7347 Display Assembly Replacement, Fan: 5 단계, 이미지 1/2 Dell Inspiron 13-7347 Display Assembly Replacement, Fan: 5 단계, 이미지 2/2
    • You should be able to identify the fan.
    • This is the 2.5 mm JIS #00 screw.
    • This is the 4 mm JIS #00 screw.
  6. Dell Inspiron 13-7347 Display Assembly Replacement: 6 단계, 이미지 1/2 Dell Inspiron 13-7347 Display Assembly Replacement: 6 단계, 이미지 2/2
    • Remove the 2.5 mm JIS #00 screw.
    • Remove the 4 mm JIS #00 screw.
  7. Dell Inspiron 13-7347 Display Assembly Replacement: 7 단계, 이미지 1/2 Dell Inspiron 13-7347 Display Assembly Replacement: 7 단계, 이미지 2/2
    • Detach the cable that connects the fan and the motherboard.
    • The cable is extremely fragile.
  8. Dell Inspiron 13-7347 Display Assembly Replacement: 8 단계, 이미지 1/2 Dell Inspiron 13-7347 Display Assembly Replacement: 8 단계, 이미지 2/2
    • Detach the cord that connects the fan and the motherboard.
  9. Dell Inspiron 13-7347 Display Assembly Replacement: 9 단계, 이미지 1/1
    • Remove the fan.
  10. Dell Inspiron 13-7347 Display Assembly Replacement, Hard Drive: 10 단계, 이미지 1/2 Dell Inspiron 13-7347 Display Assembly Replacement, Hard Drive: 10 단계, 이미지 2/2
    • Using a Phillips #0 screwdriver, loosen and remove the two 3.0 mm hard drive screws.
    • Lift the hard drive up and out of the device.
  11. Dell Inspiron 13-7347 Display Assembly Replacement, Display Assembly: 11 단계, 이미지 1/3 Dell Inspiron 13-7347 Display Assembly Replacement, Display Assembly: 11 단계, 이미지 2/3 Dell Inspiron 13-7347 Display Assembly Replacement, Display Assembly: 11 단계, 이미지 3/3
    • Using a Phillips #0 screwdriver, remove the three 3.0 mm heat sink screws.
    • Remove the Heat Sink.
    • When reinstalling the heat sink, be sure to clean both contact surfaces with isopropyl alcohol and reapply thermal paste.
  12. Dell Inspiron 13-7347 Display Assembly Replacement: 12 단계, 이미지 1/1
    • Using a Phillips #0 screwdriver, remove the two 5.0 mm screws on the metal bracket.
    • Remove the metal bracket.
  13. Dell Inspiron 13-7347 Display Assembly Replacement: 13 단계, 이미지 1/1
    • Loosen and reposition the display cable.
    • The display cable will not be removed. Do not attempt to remove the display cable.
  14. Dell Inspiron 13-7347 Display Assembly Replacement: 14 단계, 이미지 1/3 Dell Inspiron 13-7347 Display Assembly Replacement: 14 단계, 이미지 2/3 Dell Inspiron 13-7347 Display Assembly Replacement: 14 단계, 이미지 3/3
    • Using a Phillips #0 screwdriver, remove the 5.0mm screw on the left display hinge bracket.
    • Using a Phillips #0 screwdriver, remove the two 5.0mm screws on the right display hinge bracket.
    • Lift and remove the display assembly.
결론
Kyle Smith
회원 가입일: 10/02/19
331 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 13
전체 시간: 605
