주요 콘텐츠로 건너뛰기
Dell Inspiron 13-7352 Battery Replacement
필요한 것
  1. Dell Inspiron 13-7352 Battery Replacement, Battery: 1 단계, 이미지 1/3 Dell Inspiron 13-7352 Battery Replacement, Battery: 1 단계, 이미지 2/3 Dell Inspiron 13-7352 Battery Replacement, Battery: 1 단계, 이미지 3/3
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use a Phillips screwdriver to remove the ten 7.5mm screws that securing the back panel.
    • Use the plastic opening tool to pry up and loosen the back panel.
    • Remove the back panel.
  2. Dell Inspiron 13-7352 Battery Replacement: 2 단계, 이미지 1/2 Dell Inspiron 13-7352 Battery Replacement: 2 단계, 이미지 2/2
    • Use a Phillips screwdriver to remove the two 3 mm screws securing the battery.
    • Unclip the hard drive wire from the battery.
  3. Dell Inspiron 13-7352 Battery Replacement: 3 단계, 이미지 1/1
    • Gently remove the battery from the rest of the device.
결론
For optimal performance, after completing this guide, calibrate your newly installed battery.
다른 8명이 해당 안내서를 완성하였습니다.
Mikinna Martin
회원 가입일: 09/25/15
458 평판
안내서 2개 작성하였습니다
University of Tampa, Team 1-5, Whiteside Fall 2015 University of Tampa, Team 1-5, Whiteside Fall 2015 회원
UT-WHITESIDE-F15S1G5
3 회원들
안내서 6개 작성하였습니다
댓글 3개
Last I looked up for a different model there was a video..
pc2053 - 답글
Hello,
My Dell Inspiron 13-7352 won't turn on; I was using it when there was power outage and I totally drained the battery and it went off automatically, after the power came back I charged it the whole night but it still totally doesn't turn on. I tried to long-press the power button but nothing happens. I am 99% sure that the reason was using it on battery until the whole charge was gone. Please help!
jobgondwe - 답글
My Dell did the same thing. I followed the above instructions to remove the battery and then put it right back in. Plugged into power and wa-la...it powered up. So simple. Thanks.
pcoladeb - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 5
30일 전: 24
전체 시간: 24,989
