이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
A misfunctioning or broken Keyboard and/or Touchpad is actually an inexpensive fix that may save you from having to throw away an otherwise working device.
Please review attached safety information before beginning repair.
Safety
Please review safety information found here before working on your device.
필요한 것
Remove the 10 - M2.5 x 8mm screws located on the bottom of the device.
Detach and remove the Bottom Base Cover using an opening tool to pry it off.
다른 5명이 해당 안내서를 완성하였습니다.
