주요 콘텐츠로 건너뛰기
Dell Inspiron 14-5415 Hard Drive Replacement
필요한 것
  1. Dell Inspiron 14-5415 Hard Drive Replacement, Back Cover: 1 단계, 이미지 1/1
    • Close the lid and turn the laptop over to access the back cover.
  2. Dell Inspiron 14-5415 Hard Drive Replacement: 2 단계, 이미지 1/1
    • Remove the five 4 mm screws from the back of the laptop using a Phillips #0 screwdriver.
    • Loosen the two remaining captive screws using a Phillips #0 screwdriver.
    • Captive screws tend to have a slightly larger head than normal screws, so it is important to use the correct size screwdriver to avoid damaging the screw or the device.
  3. Dell Inspiron 14-5415 Hard Drive Replacement, Hard Drive: 3 단계, 이미지 1/2 Dell Inspiron 14-5415 Hard Drive Replacement, Hard Drive: 3 단계, 이미지 2/2
    • Remove the screw from the hard drive using a Phillips #00 screwdriver.
  4. Dell Inspiron 14-5415 Hard Drive Replacement: 4 단계, 이미지 1/1
    • Carefully pull the hard drive out of its position.
    • Be sure to handle the hard drive with care. It should not need to be pulled hard to remove.
결론
Ilana Ek-Adler
회원 가입일: 02/09/23
85 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 12
전체 시간: 200
