소개
Pretty straight forward repair. Biggest issue I found while doing it, is that spring clip that holds the screw to the cover. It does have a tendency to come off during the removal of the cover. It could theoretical fall into the opening of the drive bay. Make sure you know where it is so that it does not get lost.
필요한 것
Here is a Dell Inspiron 14z N411z with a defective hard drive.
On the back side is only one cover for the hard drive as well as the memory module.
Remove the Phillips screw on the bottom right corner of the cover.
다른 2명이 해당 안내서를 완성하였습니다.
