주요 콘텐츠로 건너뛰기
Dell Inspiron 14z Hard Drive Replacement
필요한 것
  1. Dell Inspiron 14z Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/3 Dell Inspiron 14z Hard Drive Replacement, Hard Drive: 1 단계, 이미지 2/3 Dell Inspiron 14z Hard Drive Replacement, Hard Drive: 1 단계, 이미지 3/3
    • Here is a Dell Inspiron 14z N411z with a defective hard drive.
    • On the back side is only one cover for the hard drive as well as the memory module.
    • Remove the Phillips screw on the bottom right corner of the cover.
  2. Dell Inspiron 14z Hard Drive Replacement: 2 단계, 이미지 1/3 Dell Inspiron 14z Hard Drive Replacement: 2 단계, 이미지 2/3 Dell Inspiron 14z Hard Drive Replacement: 2 단계, 이미지 3/3
    • Use a plastic opening tool to unsnap the cover from the back case.
    • Move the tool gently along the corner of the cover.
    • The screw that holds the cover on, has a spring clip that keeps the screw attached to the cover. during removal of the screw, this clip might come off.
  3. Dell Inspiron 14z Hard Drive Replacement: 3 단계, 이미지 1/3 Dell Inspiron 14z Hard Drive Replacement: 3 단계, 이미지 2/3 Dell Inspiron 14z Hard Drive Replacement: 3 단계, 이미지 3/3
    • With the removal of the cover, the hard drive is immediately visible. Remove the four screws securing the hard drive bracket.
    • Slide the hard drive to the opposite end of the connector. This will free the connection.
  4. Dell Inspiron 14z Hard Drive Replacement: 4 단계, 이미지 1/3 Dell Inspiron 14z Hard Drive Replacement: 4 단계, 이미지 2/3 Dell Inspiron 14z Hard Drive Replacement: 4 단계, 이미지 3/3
    • Pull gently on the black tab on the hard drive. This will remove the drive and caddy from the computer.
    • Remove the two Phillips screws on the right side,
    • and the two Phillips screws on the left side.
  5. Dell Inspiron 14z Hard Drive Replacement: 5 단계, 이미지 1/1
    • The hard drive is now removed from the caddy and the replacement can be installed.
결론
다른 2명이 해당 안내서를 완성하였습니다.
oldturkey03
회원 가입일: 09/29/10
784,298 평판
안내서 119개 작성하였습니다
Global Fixers Global Fixers 회원
Community
33 회원들
안내서 560개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 15
전체 시간: 12,785
