주요 콘텐츠로 건너뛰기
Dell Inspiron 15 5577 Gaming Battery Replacement
필요한 것
  1. Dell Inspiron 15 5577 Gaming Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Be sure to power off and unplug your device before you begin your repair.
    • Unscrew the back cover using a Phillips #0 screwdriver.
  2. Dell Inspiron 15 5577 Gaming Battery Replacement: 2 단계, 이미지 1/1
    • Remove the back cover using an opening tool.
  3. Dell Inspiron 15 5577 Gaming Battery Replacement: 3 단계, 이미지 1/2 Dell Inspiron 15 5577 Gaming Battery Replacement: 3 단계, 이미지 2/2
    • Use a T8 Torx driver to remove the five screws around the battery.
  4. Dell Inspiron 15 5577 Gaming Battery Replacement: 4 단계, 이미지 1/1
    • Remove the Battery Cable by gently tugging it perpendicular from the surface it is attached to.
  5. Dell Inspiron 15 5577 Gaming Battery Replacement: 5 단계, 이미지 1/1
    • Pull the battery out of the laptop by prying it away from the laptop. If you're having difficulty removing it, you can also use a plastic opening tool.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
[deleted]
회원 가입일: 10/31/19
346 평판
안내서 2개 작성하였습니다
댓글 한 개
Thank you, you guys rock
Random User - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 11
30일 전: 47
전체 시간: 5,149
