주요 콘텐츠로 건너뛰기
Dell Inspiron 15 7579 Battery Replacement
필요한 것
  1. Dell Inspiron 15 7579 Battery Replacement, Back Panel: 1 단계, 이미지 1/1
    • Remove the ten 7.9 mm screws with the Phillips PH0 screwdriver.
  2. Dell Inspiron 15 7579 Battery Replacement: 2 단계, 이미지 1/2 Dell Inspiron 15 7579 Battery Replacement: 2 단계, 이미지 2/2
    • Insert metal spudger into a gap in between the back panel and the back of the screen.
    • Pry off the back panel using the metal spudger as a lever, and remove the back panel by lifting the rest off by hand.
  3. Dell Inspiron 15 7579 Battery Replacement, Battery: 3 단계, 이미지 1/2 Dell Inspiron 15 7579 Battery Replacement, Battery: 3 단계, 이미지 2/2
    • Remove the two 7.8 mm long screws on the left side of the battery with the Phillips #1 screwdriver.
  4. Dell Inspiron 15 7579 Battery Replacement: 4 단계, 이미지 1/1
    • Pull out the fabric clip that attaches the battery to the main board from the connector by hand.
    • Remove the battery from the device.
결론
다른 9명이 해당 안내서를 완성하였습니다.
Inaki Madrigal
회원 가입일: 04/23/18
760 평판
안내서 6개 작성하였습니다
Cal Poly, Team S24-G9, Maness Spring 2018 Cal Poly, Team S24-G9, Maness Spring 2018 회원
CPSU-MANESS-S18S24G9
4 회원들
안내서 6개 작성하였습니다
댓글 2개
Thanks! Very helpful and to the point!
You ARE TECHNICALLY missing one step however, removing the fabric ribbon from the old battery at the end. Yes, it seems like common sense but…
Anyways, thanks.
Thomas Keats - 답글
Thanks for the help, worked well.
Remember the connector needs to be removed from the old battery and re-installed in the new. I used a small slotted screwdriver.
A. Holness
June 7, 2020
andrew.w.holness - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 36
전체 시간: 6,902
