소개
Before replacing the speakers, we recommend starting out with our troubleshooting guide. If you are still having problems, follow the steps below to replace your speakers.
필요한 것
Remove the two 7.8 mm long screws on the left side of the battery with the Phillips #1 screwdriver.
After battery is removed, locate the left and right speakers.
On the right speaker assembly, remove the pin connector using the tweezers.
거의 끝나갑니다!
결론
