주요 콘텐츠로 건너뛰기
Dell Inspiron 15-5552 Keyboard Replacement
필요한 것
  1. Dell Inspiron 15-5552 Keyboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Make sure the laptop is powered down before you remove the battery.
  2. Dell Inspiron 15-5552 Keyboard Replacement: 2 단계, 이미지 1개 중 1개
    • Locate the battery release switch on the bottom of the laptop.
  3. Dell Inspiron 15-5552 Keyboard Replacement: 3 단계, 이미지 1개 중 1개
    • Slide the battery release switch away from the lock symbol towards the “unlock” position.
    • You can tell that the battery is unlocked once you hear a "click."
  4. Dell Inspiron 15-5552 Keyboard Replacement: 4 단계, 이미지 2개 중 1개 Dell Inspiron 15-5552 Keyboard Replacement: 4 단계, 이미지 2개 중 2개
    • Rotate the battery outward by lifting the bottom lip that pops out.
    • Continue rotating the battery towards the top of the laptop until the battery is completely removed.
  5. Dell Inspiron 15-5552 Keyboard Replacement, Keyboard: 5 단계, 이미지 2개 중 1개 Dell Inspiron 15-5552 Keyboard Replacement, Keyboard: 5 단계, 이미지 2개 중 2개
    • Keyboard
    • Insert a spudger next to the 5 plastic indents located at the top of the keyboard and gently pry to release the securing clips.
  6. Dell Inspiron 15-5552 Keyboard Replacement: 6 단계, 이미지 2개 중 1개 Dell Inspiron 15-5552 Keyboard Replacement: 6 단계, 이미지 2개 중 2개
    • Lift the keyboard off of the computer. *Be careful not to tear the ribbon that attaches the back of the keyboard to the computer when lifting it.*
  7. Dell Inspiron 15-5552 Keyboard Replacement: 7 단계, 이미지 1개 중 1개
    • Flip the keyboard over onto the palm-rest assembly.
  8. Dell Inspiron 15-5552 Keyboard Replacement: 8 단계, 이미지 2개 중 1개 Dell Inspiron 15-5552 Keyboard Replacement: 8 단계, 이미지 2개 중 2개
    • Flip the black securing bar near the base of the ribbon with a spudger to release the ribbon from the computer.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Chandler Champion
회원 가입일: 01/23/18
364 평판
안내서 3개를 작성함
댓글 한 개
After reading this it took all of 5 minutes to remove the key board thank you now to see why this computer will not power up!!!
Ronald Giles - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 22
전체 시간: 279
