주요 콘텐츠로 건너뛰기
Dell Inspiron 15-5567 Wireless Card Replacement
필요한 것
  1. Dell Inspiron 15-5567 Wireless Card Replacement, Back Cover: 1 단계, 이미지 1/3 Dell Inspiron 15-5567 Wireless Card Replacement, Back Cover: 1 단계, 이미지 2/3 Dell Inspiron 15-5567 Wireless Card Replacement, Back Cover: 1 단계, 이미지 3/3
    • Orient the laptop with the back cover facing upward and the INSPIRON engraving reads legible (not flipped).
    • Remove 13 M2.5x8mm screws using a Philips #0 screwdriver.
    • Remove two M2x4mm screws using the same screwdriver.
  2. Dell Inspiron 15-5567 Wireless Card Replacement: 2 단계, 이미지 1/2 Dell Inspiron 15-5567 Wireless Card Replacement: 2 단계, 이미지 2/2
    • Insert the blue plastic opening tool into the crease of the CD driver, and pop it open.
    • Slide the rest of it out with your hand.
  3. Dell Inspiron 15-5567 Wireless Card Replacement: 3 단계, 이미지 1/3 Dell Inspiron 15-5567 Wireless Card Replacement: 3 단계, 이미지 2/3 Dell Inspiron 15-5567 Wireless Card Replacement: 3 단계, 이미지 3/3
    • Remove three M2x2mm screws underneath the CD driver with the same Philips #0 screwdriver.
    • Place the blue plastic opening tool in the crease of the cover and push it upward to open the back cover.
    • Grab the corners of the cover firmly and lift it up.
    • Some parts are weaker than others; open it gently from corners.
  4. Dell Inspiron 15-5567 Wireless Card Replacement, Wireless Card: 4 단계, 이미지 1/3 Dell Inspiron 15-5567 Wireless Card Replacement, Wireless Card: 4 단계, 이미지 2/3 Dell Inspiron 15-5567 Wireless Card Replacement, Wireless Card: 4 단계, 이미지 3/3
    • Remove one M2x3mm screw from the bracket holding the card using a Phillips #0 screwdriver.
    • Lift and remove the bracket with your hand.
  5. Dell Inspiron 15-5567 Wireless Card Replacement: 5 단계, 이미지 1/3 Dell Inspiron 15-5567 Wireless Card Replacement: 5 단계, 이미지 2/3 Dell Inspiron 15-5567 Wireless Card Replacement: 5 단계, 이미지 3/3
    • Disconnect the antennae cables connected to the card using the opening tool.
    • Slide the wireless card off of its socket and lift it with your hand and remove it.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Sattam Bakolka
회원 가입일: 01/14/20
732 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 24
전체 시간: 1,174
