주요 콘텐츠로 건너뛰기
Dell Inspiron 15-7559 Battery Replacement
필요한 것
  1. Dell Inspiron 15-7559 Battery Replacement, Back Panel: 1 단계, 이미지 1/1
    • Turn off the computer.
    • Disconnect the charging cable from the computer.
    • Failure to turn off the device and disconnect the cable could lead to personal injury or device damage.
    • Flip the computer upside down.
  2. Dell Inspiron 15-7559 Battery Replacement: 2 단계, 이미지 1/3 Dell Inspiron 15-7559 Battery Replacement: 2 단계, 이미지 2/3 Dell Inspiron 15-7559 Battery Replacement: 2 단계, 이미지 3/3
    • Remove the captive screw located on the top section of the back panel, using a Philips #1 screwdriver.
    • Keep in mind that the screw cannot be fully removed from the panel, even when fully loosened.
  3. Dell Inspiron 15-7559 Battery Replacement: 3 단계, 이미지 1/3 Dell Inspiron 15-7559 Battery Replacement: 3 단계, 이미지 2/3 Dell Inspiron 15-7559 Battery Replacement: 3 단계, 이미지 3/3
    • Use the blue, plastic opening tool to gently pry a section of the back panel open.
    • Next slide the opening tool around the back panel to disconnect the clips holding the panel in place.
    • After the clips have been disconnected, the back panel can then be easily lifted off the computer.
  4. Dell Inspiron 15-7559 Battery Replacement, Battery: 4 단계, 이미지 1/1
    • Locate the battery on the bottom left side of the laptop.
  5. Dell Inspiron 15-7559 Battery Replacement: 5 단계, 이미지 1/3 Dell Inspiron 15-7559 Battery Replacement: 5 단계, 이미지 2/3 Dell Inspiron 15-7559 Battery Replacement: 5 단계, 이미지 3/3
    • Unscrew the 5 x 2mm x 5mm screws, using the T8 Torx screwdriver.
  6. Dell Inspiron 15-7559 Battery Replacement: 6 단계, 이미지 1/3 Dell Inspiron 15-7559 Battery Replacement: 6 단계, 이미지 2/3 Dell Inspiron 15-7559 Battery Replacement: 6 단계, 이미지 3/3
    • Using the tab above the battery, raise the battery far enough to disconnect the cables attached to it.
    • Using your hand grab the white portion connecting the cables to the battery and disconnect it.
    • Do not pull on the cables directly. This would risk damaging them or tearing them from the device.
  7. Dell Inspiron 15-7559 Battery Replacement: 7 단계, 이미지 1/1
    • Now lift the battery from the device to remove it.
결론
다른 11명이 해당 안내서를 완성하였습니다.
Trenton Greevebiester
회원 가입일: 10/19/17
1,536 평판
안내서 6개 작성하였습니다
UW Tacoma, Team S3-G2, Liner Fall 2017 UW Tacoma, Team S3-G2, Liner Fall 2017 회원
UWT-LINER-F17S3G2
5 회원들
안내서 9개 작성하였습니다
댓글 2개
Cool, that’s the easy part. How do you tell the UEFI that it’s okay to charge the new battery?
Stefan Bacon - 답글
is it ok to replace the 11.4V battery with the 11.1V version?
Payton DePietro - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 16
30일 전: 77
전체 시간: 16,459
