주요 콘텐츠로 건너뛰기
소개
Taking out the battery is easy to replace when needed. It may need to be replaced if the battery dies quickly.
부품
지정된 부품이 없습니다.
  1. Turn off laptop before beginning.
    • Turn off laptop before beginning.
    • Place the laptop upside down on a flat, stable surface.
  2. Remove the 3mm screw in the location shown, using a Phillips #1 screwdriver. Remove the 3mm screw in the location shown, using a Phillips #1 screwdriver.
    • Remove the 3mm screw in the location shown, using a Phillips #1 screwdriver.
  3. Apple Watch Kits
    Screen and battery repairs just got easier.
    지금 장보기
    Apple Watch Kits
    지금 장보기
  4. Remove the panel from the sides and pull it out at an angle towards you.
    • Remove the panel from the sides and pull it out at an angle towards you.
  5. Remove the five 3mm screws on the battery with a Torx (T8) screwdriver in the locations shown. Remove the five 3mm screws on the battery with a Torx (T8) screwdriver in the locations shown.
    • Remove the five 3mm screws on the battery with a Torx (T8) screwdriver in the locations shown.
  6. Disconnect the power cord from the battery  by using a pair of tweezers, your fingers, or the opening tools from the iFixit pro tech tool kit. Pinch the clips on the left and right side while pulling on the cord at the same time.
    • Disconnect the power cord from the battery by using a pair of tweezers, your fingers, or the opening tools from the iFixit pro tech tool kit.
    • Pinch the clips on the left and right side while pulling on the cord at the same time.
  7. Pull the battery towards you.
    • Pull the battery towards you.
    • Make sure to pull at an upward angle.
결론
Dallas Lamorie
회원 가입일: 2018년 09월 30일
425 평판
안내서 3개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 18
지난 30일: 83
전체 시간: 358
