주요 콘텐츠로 건너뛰기
Dell Inspiron 1525 Heat Sink Replacement
필요한 것
  1. Dell Inspiron 1525 Heat Sink Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Locate the battery release switch on the bottom of the laptop.
  2. Dell Inspiron 1525 Heat Sink Replacement: 2 단계, 이미지 2개 중 1개 Dell Inspiron 1525 Heat Sink Replacement: 2 단계, 이미지 2개 중 2개
    • Slide the battery release switch away from the lock symbol until you hear the battery click.
    • Slide the battery towards the back of the laptop until it comes free.
  3. Dell Inspiron 1525 Heat Sink Replacement, Bottom Cover: 3 단계, 이미지 2개 중 1개 Dell Inspiron 1525 Heat Sink Replacement, Bottom Cover: 3 단계, 이미지 2개 중 2개
    • Remove/loosen the eight 4.80 mm Phillips #1 screws securing the bottom panel.
    • The screws may only need to be loosened, as they are generally retained by plastic washers.
    • Remove the bottom panel.
  4. Dell Inspiron 1525 Heat Sink Replacement, Heat Sink: 4 단계, 이미지 3개 중 1개 Dell Inspiron 1525 Heat Sink Replacement, Heat Sink: 4 단계, 이미지 3개 중 2개 Dell Inspiron 1525 Heat Sink Replacement, Heat Sink: 4 단계, 이미지 3개 중 3개
    • Loosen the five #1 Phillips screws securing the heat sink and clean it with compressed air
    • These screws are attached to the heat sink assembly.
    • Gently lift the heat sink from side indicated in the picture.
    • The heat sink may feel like it is glued to the chips because of the thermal paste. Gently wiggle the heat sink back and forth to help break it free.
    • Be sure to thoroughly clean off the old thermal paste and apply new thermal paste before reinstalling the heat sink. Follow our thermal paste application guide for detailed instructions.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Miroslav Djuric
159,533 평판
안내서 144개를 작성함
댓글 한 개
Is there any option to modify the heatsink for better cooling
manashpratim saikia - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 21
전체 시간: 7,926
