주요 콘텐츠로 건너뛰기
Dell Inspiron 7000 2 in 1 Battery Replacement
필요한 것
  1. Dell Inspiron 7000 2 in 1 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Flip your Dell Inspiron 7000 2 in 1 laptop upside down to get started. Find the locations of all the 10 screws.
    • Remember to turn the laptop off before you begin the repair.
  2. Dell Inspiron 7000 2 in 1 Battery Replacement: 2 단계, 이미지 1/1
    • Using your Phillips #00 screwdriver, remove the ten 7.00 mm screws at the bottom of the laptop.
  3. Dell Inspiron 7000 2 in 1 Battery Replacement: 3 단계, 이미지 1/3 Dell Inspiron 7000 2 in 1 Battery Replacement: 3 단계, 이미지 2/3 Dell Inspiron 7000 2 in 1 Battery Replacement: 3 단계, 이미지 3/3
    • Insert the spudger in the gap between the bottom cover and the frame. Then, use it as a wedge and work your way around the perimeter. This will pop open the bottom cover of the laptop.
  4. Dell Inspiron 7000 2 in 1 Battery Replacement: 4 단계, 이미지 1/1
    • Find the battery located at the bottom right corner of the laptop.
  5. Dell Inspiron 7000 2 in 1 Battery Replacement: 5 단계, 이미지 1/1
    • Now remove the four 4.0 mm Phillips #00 screws located at each corner of the battery.
  6. Dell Inspiron 7000 2 in 1 Battery Replacement: 6 단계, 이미지 1/1
    • Remove the battery pin that is connecting the motherboard to the battery by pulling out the pin gently.
    • Remember to safely recycle your old laptop battery.
  7. Dell Inspiron 7000 2 in 1 Battery Replacement: 7 단계, 이미지 1/1
    • Reinsert the battery pin into the new battery and place it back into its position.
  8. Dell Inspiron 7000 2 in 1 Battery Replacement: 8 단계, 이미지 1/1
    • Screw the four 4.0 mm Phillips #00 head screws for the battery back into place to make sure the battery is held on securely.
  9. Dell Inspiron 7000 2 in 1 Battery Replacement: 9 단계, 이미지 1/1
    • Place the cover back onto the laptop and press down on all corners and sides.
    • Make sure to listen for a click to ensure the cover is properly secured.
  10. Dell Inspiron 7000 2 in 1 Battery Replacement: 10 단계, 이미지 1/1
    • Use the Phillips #00 screwdriver to replace the ten 7.00 mm screws on the back cover.
결승점
다른 3명이 해당 안내서를 완성하였습니다.
Neelay Patel
회원 가입일: 09/17/21
255 평판
안내서 1개 작성함
York University, Team E-31, Melo-Thaiss Fall 2021 York University, Team E-31, Melo-Thaiss Fall 2021 회원
YORK-MELO-THAISS-F21SEG31
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 42
30일 전: 138
전체 시간: 5,894
