주요 콘텐츠로 건너뛰기
Dell Latitude 3189 Battery Replacement
필요한 것
  1. Dell Latitude 3189 Battery Replacement, Lower Case: 1 단계, 이미지 1/2 Dell Latitude 3189 Battery Replacement, Lower Case: 1 단계, 이미지 2/2
    • Before beginning, power off and unplug the device.
    • Use a Phillips screwdriver to loosen the seven captive screws that secure the lower case.
  2. Dell Latitude 3189 Battery Replacement: 2 단계, 이미지 1/3 Dell Latitude 3189 Battery Replacement: 2 단계, 이미지 2/3 Dell Latitude 3189 Battery Replacement: 2 단계, 이미지 3/3
    • Insert a nylon spudger between the lower case and chassis at the two hinge spaces on the back side of the laptop and pry up the lower case.
    • Do not use metal items to pry the base cover off, like a screwdriver, as it could slip and damage internal components.
    • Avoid prying at the ports.
  3. Dell Latitude 3189 Battery Replacement: 3 단계, 이미지 1/2 Dell Latitude 3189 Battery Replacement: 3 단계, 이미지 2/2
    • Grip and lift the lower case up and away.
    • If you feel any significant resistance, double check that all of the screws are loosened.
  4. Dell Latitude 3189 Battery Replacement: 4 단계, 이미지 1/3 Dell Latitude 3189 Battery Replacement: 4 단계, 이미지 2/3 Dell Latitude 3189 Battery Replacement: 4 단계, 이미지 3/3
    • Before performing any operations within the laptop, unplug the battery.
    • Pull the white battery connector directly out of its motherboard port.
    • Do not pull on the wires.
  5. Dell Latitude 3189 Battery Replacement, Battery: 5 단계, 이미지 1/2 Dell Latitude 3189 Battery Replacement, Battery: 5 단계, 이미지 2/2
    • Use a Phillips #0 screwdriver to remove the three 3.2 mm screws that secure the battery.
  6. Dell Latitude 3189 Battery Replacement: 6 단계, 이미지 1/2 Dell Latitude 3189 Battery Replacement: 6 단계, 이미지 2/2
    • Grip the battery and lift it up and out of the chassis.
결론
For optimal performance, calibrate your newly installed battery after completing this guide.
다른 한 분이 해당 안내서를 완성하였습니다.
Bryan Pratt
회원 가입일: 02/14/24
601 평판
안내서 6개 작성하였습니다
University of Memphis, Team 2-3, Sneed Spring 2024 University of Memphis, Team 2-3, Sneed Spring 2024 회원
UM-SNEED-S24S2G3
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 14
전체 시간: 62
