주요 콘텐츠로 건너뛰기
Dell Latitude 7420 Battery Replacement
필요한 것
  1. Dell Latitude 7420 Battery Replacement, Back Case: 1 단계, 이미지 1/3 Dell Latitude 7420 Battery Replacement, Back Case: 1 단계, 이미지 2/3 Dell Latitude 7420 Battery Replacement, Back Case: 1 단계, 이미지 3/3
    • Remove the eight, 7 mm screws from the back case using a Phillips #0 screwdriver.
    • Use an opening pick or opening tool and work your way around the periphery of the base cover to separate it from the chassis.
  2. Dell Latitude 7420 Battery Replacement, Battery: 2 단계, 이미지 1/2 Dell Latitude 7420 Battery Replacement, Battery: 2 단계, 이미지 2/2
    • Be sure to use an anti-static band or mat from this point onward.
    • Using the Phillips #1 screwdriver, remove the five 5 mm screws securing the battery to the motherboard.
  3. Dell Latitude 7420 Battery Replacement: 3 단계, 이미지 1/2 Dell Latitude 7420 Battery Replacement: 3 단계, 이미지 2/2
    • Use a spudger to pry up each side. Then, lift the connector straight up from its socket.
    • To reinstall, carefully position the connector, and then press it straight down until it snaps into its socket. Finger pressure is all that is required. If it won't snap home it'll be because it isn't correctly positioned. Sometimes it can take a little patience to find exactly the right position.
  4. Dell Latitude 7420 Battery Replacement: 4 단계, 이미지 1/1
    • Gently remove the battery from its housing.
결론
Xaiven Watson-torres
회원 가입일: 02/02/23
97 평판
안내서 1개 작성함
Gateway, Team 1-2, Pee Spring 2023 Gateway, Team 1-2, Pee Spring 2023 회원
GCC-PEE-S23S1G2
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 60
전체 시간: 611
