주요 콘텐츠로 건너뛰기
Dell Latitude 7420 Fan Assembly Replacement
필요한 것
  1. Dell Latitude 7420 Fan Assembly Replacement, Back Case: 1 단계, 이미지 3개 중 1개 Dell Latitude 7420 Fan Assembly Replacement, Back Case: 1 단계, 이미지 3개 중 2개 Dell Latitude 7420 Fan Assembly Replacement, Back Case: 1 단계, 이미지 3개 중 3개
    • Remove the eight, 7 mm screws from the back case using a Phillips #0 screwdriver.
    • Use an opening pick or opening tool and work your way around the periphery of the base cover to separate it from the chassis.
  2. Dell Latitude 7420 Fan Assembly Replacement, Battery: 2 단계, 이미지 2개 중 1개 Dell Latitude 7420 Fan Assembly Replacement, Battery: 2 단계, 이미지 2개 중 2개
    • Be sure to use an anti-static band or mat from this point onward.
    • Using the Phillips #1 screwdriver, remove the five 5 mm screws securing the battery to the motherboard.
  3. Dell Latitude 7420 Fan Assembly Replacement: 3 단계, 이미지 2개 중 1개 Dell Latitude 7420 Fan Assembly Replacement: 3 단계, 이미지 2개 중 2개
    • Use a spudger to pry up each side of the battery connector. Then, lift the connector straight up from its socket.
    • To reinstall, carefully position the connector, and then press it straight down until it snaps into its socket. Finger pressure is all that is required. If it won't snap home it'll be because it isn't correctly positioned. Sometimes it can take a little patience to find exactly the right position.
  4. Dell Latitude 7420 Fan Assembly Replacement: 4 단계, 이미지 2개 중 1개 Dell Latitude 7420 Fan Assembly Replacement: 4 단계, 이미지 2개 중 2개
    • Unplug the speaker cable by pulling it down, then carefully unthread the cable from the battery
  5. Dell Latitude 7420 Fan Assembly Replacement: 5 단계, 이미지 1개 중 1개
    • Gently remove the battery from its housing.
  6. Dell Latitude 7420 Fan Assembly Replacement, Fan Assembly: 6 단계, 이미지 2개 중 1개 Dell Latitude 7420 Fan Assembly Replacement, Fan Assembly: 6 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Dust Blower
    • Keeping the vents on the case of the laptop clean of dust or debris and clear of obstruction is important for the device to maintain its temperature.
    • Use a cloth and dust blower to clean the vents.
    • It's best to clean the vent when the back case has been removed from the device.
  7. Dell Latitude 7420 Fan Assembly Replacement: 7 단계, 이미지 3개 중 1개 Dell Latitude 7420 Fan Assembly Replacement: 7 단계, 이미지 3개 중 2개 Dell Latitude 7420 Fan Assembly Replacement: 7 단계, 이미지 3개 중 3개
    • If the fan is dusty, a soft cloth can be used to gently clean it.
    • Use a Phillips #00 screwdriver to remove the six 2.5 mm screws securing the fan assembly.
  8. Dell Latitude 7420 Fan Assembly Replacement: 8 단계, 이미지 3개 중 1개 Dell Latitude 7420 Fan Assembly Replacement: 8 단계, 이미지 3개 중 2개 Dell Latitude 7420 Fan Assembly Replacement: 8 단계, 이미지 3개 중 3개
    • Use the pointed tip of a spudger to carefully push on each side of the connector and remove it from the socket.
    • Remove the fan assembly.
    • When replacing the fan assembly, make sure there is thermal paste under the heat sink. Follow this guide for more information.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Nick B.
회원 가입일: 08/25/22
698 평판
안내서 4개를 작성함
Gateway, Team 1-2, Pee Spring 2023 Gateway, Team 1-2, Pee Spring 2023 회원
GCC-PEE-S23S1G2
4 회원들
안내서 10개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 41
지난 30일: 143
전체 시간: 1,678
