소개
Use this guide to replace the WLAN card in your Dell Latitude 7490 laptop.
If you are experiencing frequent connectivity issues or poor signal quality, you may need to replace your WLAN card.
필요한 것
Use a Phillips screwdriver to fully loosen the eight captive screws securing the back cover.
Insert the long side of an opening pick between the top right corner of the back cover and frame.
Pry the back cover up to release the clips securing the top right corner.
Slide the opening pick down the right edge and around the bottom right corner to release the clips.
Grip the plastic tab on the battery connector and pull straight up to disconnect it.
Use a Phillips screwdriver to remove the 3.5 mm‑long screw securing the WLAN card and its bracket.
Use tweezers or your fingers to remove the WLAN card bracket.
Insert an arm of your angled tweezers under the metal neck of one the WLAN card's coaxial connectors.
Gently lift as close to the head as possible to disconnect the cable.
Repeat the process for the second antenna cable.
Use a spudger or clean fingernail to pry up the WLAN card's notched edge until it pops up at a slight angle.
Pull the WLAN card straight out of its socket and remove it.
다른 한 분이 해당 안내서를 완성하였습니다.
