주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Use a Hair Dryer to Soften Adhesive
필요한 것
  1. How to Use a Hair Dryer to Soften Adhesive, Safety precautions: 1 단계, 이미지 1개 중 1개
    • Before you begin, make sure you have a plan in the event of a fire. If you have a swollen battery, take appropriate precautions.
    • Keep the hair dryer switched off and unplugged when not in use.
    • Avoid using extension cords to power your hair dryer. Since hair dryers require a high current draw, cheaper or old extension cords pose a greater fire risk.
    • Never heat a battery directly. If you're heating adhesive near or underneath a battery, make sure you've completely discharged the battery before applying heat.
  2. How to Use a Hair Dryer to Soften Adhesive, Set down the device: 2 단계, 이미지 1개 중 1개
    • The next four steps show how to use the hair dryer to soften strong adhesives, such as screen and frame adhesives.
    • Place your device on a clean, heat resistant surface or mat.
    • Keep flammable materials away from your work area.
  3. How to Use a Hair Dryer to Soften Adhesive, Turn on your hair dryer: 3 단계, 이미지 3개 중 1개 How to Use a Hair Dryer to Soften Adhesive, Turn on your hair dryer: 3 단계, 이미지 3개 중 2개 How to Use a Hair Dryer to Soften Adhesive, Turn on your hair dryer: 3 단계, 이미지 3개 중 3개
    • Set the temperature of your hair dryer to its hottest setting.
    • If your hair dryer also has fan speed control:
    • Set the fan setting to low for small parts, such as cables or tape.
    • Set the fan setting to high for large surfaces, such as screens or back covers.
  4. How to Use a Hair Dryer to Soften Adhesive, Soften the adhesive: 4 단계, 이미지 3개 중 1개 How to Use a Hair Dryer to Soften Adhesive, Soften the adhesive: 4 단계, 이미지 3개 중 2개 How to Use a Hair Dryer to Soften Adhesive, Soften the adhesive: 4 단계, 이미지 3개 중 3개
    • Position the nozzle of your hair dryer 2–3 inches above the device.
    • Move the hair dryer along the surface of your device.
    • Never leave your hair dryer in one spot for an extended period of time—keep it moving at all times.
    • Heat the surface until it's just too hot to touch, or as directed by the repair guide.
    • If you’re heating an OLED screen, don’t heat it over 176 °F (80 °C) or you may damage the OLED screen.
    • If you’re heating the adhesive underneath the battery, make sure the battery doesn’t go over 150 °F (66 °C) or you may damage the battery.
    • Make sure to turn off your hair dryer before setting it down to continue the repair.
  5. How to Use a Hair Dryer to Soften Adhesive: 5 단계, 이미지 3개 중 1개 How to Use a Hair Dryer to Soften Adhesive: 5 단계, 이미지 3개 중 2개 How to Use a Hair Dryer to Soften Adhesive: 5 단계, 이미지 3개 중 3개
    • Keep your hair dryer in motion while heating smaller surfaces by moving it in circles above the device.
    • Some components, such as large screens, require multiple cycles of heating and slicing. Take your time and apply more heat if the component feels stuck.
  6. How to Use a Hair Dryer to Soften Adhesive, Soften protective tape or film: 6 단계, 이미지 2개 중 1개 How to Use a Hair Dryer to Soften Adhesive, Soften protective tape or film: 6 단계, 이미지 2개 중 2개
    • This step shows how to use your hair dryer to loosen protective tape and stickers.
    • Position the nozzle of your hair dryer 2–3 inches above the device and set the fan setting to "Low".
    • Apply heat in small circles over the tape or sticker for 30 seconds.
    • Peel the tape from the device.
  7. How to Use a Hair Dryer to Soften Adhesive, Soften cable adhesive: 7 단계, 이미지 3개 중 1개 How to Use a Hair Dryer to Soften Adhesive, Soften cable adhesive: 7 단계, 이미지 3개 중 2개 How to Use a Hair Dryer to Soften Adhesive, Soften cable adhesive: 7 단계, 이미지 3개 중 3개
    • This step shows how to use your hair dryer to loosen cables adhered to your device.
    • Apply heat in small circles over the cable for 30 seconds.
    • Peel the cable from the device.
  8. How to Use a Hair Dryer to Soften Adhesive, Turn off your hair dryer: 8 단계, 이미지 2개 중 1개 How to Use a Hair Dryer to Soften Adhesive, Turn off your hair dryer: 8 단계, 이미지 2개 중 2개
    • Before continuing your repair, turn off your hair dryer and unplug it.
결론
Allow the hair dryer to cool down before you store it.
For other general electronics skills guides, click here.
다른 34명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Clay Eickemeyer
회원 가입일: 09/19/22
102,861 평판
안내서 476개를 작성함
Guide Team Guide Team 회원
Staff
10 회원들
안내서 17,683개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 54
지난 7일: 417
지난 30일: 1,696
전체 시간: 53,261
