이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Replacing a defective RAM component is pretty easy and can stop your computer from frequently crashing.
필요한 것
다른 6명이 해당 안내서를 완성하였습니다.
댓글 한 개
This model has two RAM slots. The second one is under the keypad. Carefully remove the bezel at the top of the keypad, remove the two screws holding the keypad down, then remove the keypad to expose the second slot. This RAM slot is a little bit more difficult to get to than the one on the back of the laptop, but is still very easy to access and change out.
