주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell OptiPlex GX260 CPU Replacement
  1. Dell OptiPlex GX260 CPU Replacement, Case: 1 단계, 이미지 2개 중 1개 Dell OptiPlex GX260 CPU Replacement, Case: 1 단계, 이미지 2개 중 2개
    • Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you.
    • Push the oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
    • Note: Some force may be required to push in the oval buttons open the PC case.
  2. Dell OptiPlex GX260 CPU Replacement, CPU: 2 단계, 이미지 3개 중 1개 Dell OptiPlex GX260 CPU Replacement, CPU: 2 단계, 이미지 3개 중 2개 Dell OptiPlex GX260 CPU Replacement, CPU: 2 단계, 이미지 3개 중 3개
    • Flip the green fan cover up towards you to reveal the CPU heatsink.
    • Lift the heat sink release lever
    • Remove the heat sink from the CPU and lift it out.
    • The heat sink may be adhered to the CPU by the the thermal pad or compound. If so gently twist the heat sink counter clockwise slightly and then pull the heat sink up and to the right.
    • Ensure you clean the heat sink and CPU thoroughly and apply fresh thermal compound before you reinstall the heat sink. Refer to this handy iFixit Technique if you need further information.
  3. Dell OptiPlex GX260 CPU Replacement: 3 단계, 이미지 2개 중 1개 Dell OptiPlex GX260 CPU Replacement: 3 단계, 이미지 2개 중 2개
    • Carefully release the ZIF socket - push the lever backwards to release it from the hold down tab and lift it up and to the left until it stops (roughly 90 degrees).
    • Gently lift the CPU straight up and out of the socket. There should be no resistance.
    • The CPU will only fit into the ZIF socket in one orientation so take care when reinserting it. make sure that pin A1 is located correctly
    • Take care not to bend the pins on the CPU
결론
다른 7명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Kevin Schapansky
회원 가입일: 10/05/10
1,478 평판
안내서 9개를 작성함
Cal Poly, Team 4-48, Amido Fall 2010 Cal Poly, Team 4-48, Amido Fall 2010 회원
CPSU-AMIDO-F10S4G48
4 회원들
안내서 27개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 13
지난 30일: 103
전체 시간: 10,913
