주요 콘텐츠로 건너뛰기
Dell OptiPlex GX260 Motherboard Replacement
필요한 것
  1. Dell OptiPlex GX260 Motherboard Replacement, Case: 1 단계, 이미지 1/2 Dell OptiPlex GX260 Motherboard Replacement, Case: 1 단계, 이미지 2/2
    • Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you.
    • Push the oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
    • Note: Some force may be required to push in the oval buttons open the PC case.
  2. Dell OptiPlex GX260 Motherboard Replacement, Main Fan: 2 단계, 이미지 1/2 Dell OptiPlex GX260 Motherboard Replacement, Main Fan: 2 단계, 이미지 2/2
    • Disconnect the fan cable from the motherboard.
  3. Dell OptiPlex GX260 Motherboard Replacement: 3 단계, 이미지 1/3 Dell OptiPlex GX260 Motherboard Replacement: 3 단계, 이미지 2/3 Dell OptiPlex GX260 Motherboard Replacement: 3 단계, 이미지 3/3
    • On the rear of the desktop, push the two circled black buttons straight in with a small pointed object while pulling up on the fan.
    • Once the fan is released, lift it straight up and out of the case.
  4. Dell OptiPlex GX260 Motherboard Replacement, RAM: 4 단계, 이미지 1/2 Dell OptiPlex GX260 Motherboard Replacement, RAM: 4 단계, 이미지 2/2
    • Push out on the cream colored tabs on each side of each RAM module until it pops up and out of its slot and remove the RAM.
  5. Dell OptiPlex GX260 Motherboard Replacement, Motherboard: 5 단계, 이미지 1/2 Dell OptiPlex GX260 Motherboard Replacement, Motherboard: 5 단계, 이미지 2/2
    • Disconnect the ATX power cable to the motherboard.
    • Disconnect the P4 12V(4x2) power cable from the motherboard.
  6. Dell OptiPlex GX260 Motherboard Replacement: 6 단계, 이미지 1/3 Dell OptiPlex GX260 Motherboard Replacement: 6 단계, 이미지 2/3 Dell OptiPlex GX260 Motherboard Replacement: 6 단계, 이미지 3/3
    • Disconnect the front panel ribbon cable by gently pulling it straight up.
    • Disconnect the hard drive ribbon cable by gently pulling the blue tab away from the motherboard.
    • Disconnect the optical drive ribbon cable by gently pulling the orange tab away from the motherboard.
  7. Dell OptiPlex GX260 Motherboard Replacement: 7 단계, 이미지 1/2 Dell OptiPlex GX260 Motherboard Replacement: 7 단계, 이미지 2/2
    • Disconnect the floppy drive drive ribbon cable by gently pulling the black tab away from the motherboard.
    • Disconnect the optical drive audio cable connector from the motherboard.
    • Disconnect the audio input/output cable from the motherboard.
  8. Dell OptiPlex GX260 Motherboard Replacement: 8 단계, 이미지 1/2 Dell OptiPlex GX260 Motherboard Replacement: 8 단계, 이미지 2/2
    • Lift the metal tab near the right corner of the motherboard.
    • Pull the green tab toward the front of the PC to release the motherboard.
    • From the rear of the PC, push the ports in while lifting the motherboard up and flipping it away from you.
  9. Dell OptiPlex GX260 Motherboard Replacement: 9 단계, 이미지 1/3 Dell OptiPlex GX260 Motherboard Replacement: 9 단계, 이미지 2/3 Dell OptiPlex GX260 Motherboard Replacement: 9 단계, 이미지 3/3
    • Stand the motherboard up as shown.
    • Insert the flat end of a spudger into the slot in the motherboard mounting plate and press the release tab while pushing the extension plate to the right with your thumbs until it comes off..
  10. Dell OptiPlex GX260 Motherboard Replacement: 10 단계, 이미지 1/3 Dell OptiPlex GX260 Motherboard Replacement: 10 단계, 이미지 2/3 Dell OptiPlex GX260 Motherboard Replacement: 10 단계, 이미지 3/3
    • Remove the screw at the rear of the motherboard.
    • Grasp the heat sink with your left hand and the I/O port panel with your right hand and pull to separate motherboard from the metal base.
    • If you are replacing the motherboard refer to the great iFixit guide for removing the CPU.
결론
다른 15명이 해당 안내서를 완성하였습니다.
Kevin Schapansky
회원 가입일: 10/05/10
1,457 평판
안내서 9개 작성하였습니다
Cal Poly, Team 4-48, Amido Fall 2010 Cal Poly, Team 4-48, Amido Fall 2010 회원
CPSU-AMIDO-F10S4G48
4 회원들
안내서 27개 작성하였습니다
댓글 4개
Mines stuck for some reason I almost bent the frame from pushing the ports in while lifting and pulling the tray tab away
james dee - 답글
make sure you doing it the correct side!
Robert Stokes-Barnett -
muy bueno gracias bro
Tony Fernandez - 답글
Mine did not have the big green fan in back. Rest of the disassembly was similar, until I got to actually removing the PCB from the metal back plate. This says to simply slide it forward while holding the plate in place. Yeah… well, in theory. It actually took a fair amount of gentle prying to get the PCB to slide forward. The key is the little metal grounding clips in the corners. The fingers do not actually present much pressure. However, the vertical metal to which they press is an overhang. So the trick is to gently FORCE the PCB forward at each rear corner until such time as the overhang no longer exists. At this point the vertical metal tab will be full back against their respective slots. The PCB will simply lift out then.
jknox - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 18
30일 전: 71
전체 시간: 38,611
