소개
This guide is useful for when your speakers, microphone, or headphones cannot work when plugged into your desktop. The rear audio jacks are mostly used for accessories to a desktop that are meant to work with the desktop at all times. So making sure these jacks are functioning can be important.
Before beginning this guide, ensure you know how to solder. Here is a link to a helpful soldering guide for beginners: How To Solder and Desolder Connections
필요한 것
Remove the side panel/cover
Pull the slide at the top back.
This releases the panel, and it can be removed easily.
Remove the back cover.
Unscrew the 3 screws at the back, next to the power cable slot.
Pull along the sides of the cover bit by bit to remove each holder from its respective slot
