소개
This guide shows how to remove and replace the battery for the Dell Precision 5520 laptop.
For your safety, discharge your battery below 25% before disassembling your device. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
필요한 것
Turn the system badge flap over (1) and then remove the ten M2x3 screws that secure the base cover to the computer (2).
Pry the edges of the base cover and lift it to remove it from the computer.
Disconnect the battery cable from the system board [1].
Remove the seven M2x4 screws that secure the battery to the computer [2].
Lift the battery off the computer [3].
다른 10명이 해당 안내서를 완성하였습니다.
댓글 2개
Great directions. Simple, yet precise. Took less than five minutes.
Sam Kamara - 답글
Easy peasy. Great instruction, exact parts with exact tools. Great price. Thanks IFIXIT!
