소개
Use this guide to replace the headphone jack on your Dell Streak 7. This guide will show you how to remove the old headphone jack.
필요한 것
Insert the spudger under the capacitive button panel, and slide the spudger all the way around.
Using the spudger, disconnect the ribbon cable by lifting up on the connector.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
