주요 콘텐츠로 건너뛰기
Dell Vostro 1320 USB Port Replacement
필요한 것
  1. Dell Vostro 1320 USB Port Replacement, USB Port: 1 단계, 이미지 1/1
    • Remove the battery from the computer.
  2. Dell Vostro 1320 USB Port Replacement: 2 단계, 이미지 1/1
    • Remove all visible screws from the bottom of the computer.
  3. Dell Vostro 1320 USB Port Replacement: 3 단계, 이미지 1/3 Dell Vostro 1320 USB Port Replacement: 3 단계, 이미지 2/3 Dell Vostro 1320 USB Port Replacement: 3 단계, 이미지 3/3
    • Use a metal spudger to remover the covers of each section that you removed screws from.
    • Once the cover is removed from the hard drive remove the hard drive by gently tugging it out.
  4. Dell Vostro 1320 USB Port Replacement: 4 단계, 이미지 1/1
  5. Dell Vostro 1320 USB Port Replacement: 5 단계, 이미지 1/3 Dell Vostro 1320 USB Port Replacement: 5 단계, 이미지 2/3 Dell Vostro 1320 USB Port Replacement: 5 단계, 이미지 3/3
    • You must first unscrew the screws holding the wire in place.
    • Unhook the wire that the metal spudger is pointing at.
  6. Dell Vostro 1320 USB Port Replacement: 6 단계, 이미지 1/1
  7. Dell Vostro 1320 USB Port Replacement: 7 단계, 이미지 1/2 Dell Vostro 1320 USB Port Replacement: 7 단계, 이미지 2/2
    • Undo the screws holding the screen to the computer base.
  8. Dell Vostro 1320 USB Port Replacement: 8 단계, 이미지 1/1
    • Unplug the wires connecting the screen to the base.
    • The screen should come free and is able to be removed completely.
  9. Dell Vostro 1320 USB Port Replacement: 9 단계, 이미지 1/2 Dell Vostro 1320 USB Port Replacement: 9 단계, 이미지 2/2
    • Unplug the two blue labeled wires.
  10. Dell Vostro 1320 USB Port Replacement: 10 단계, 이미지 1/3 Dell Vostro 1320 USB Port Replacement: 10 단계, 이미지 2/3 Dell Vostro 1320 USB Port Replacement: 10 단계, 이미지 3/3
    • Detach the black plastic cover by loosening it with a metal spudger.
  11. Dell Vostro 1320 USB Port Replacement: 11 단계, 이미지 1/1
    • Unplug the wire that the metal spudger is pointing to.
  12. Dell Vostro 1320 USB Port Replacement: 12 단계, 이미지 1/1
    • Unscrew the USB port.
  13. Dell Vostro 1320 USB Port Replacement: 13 단계, 이미지 1/2 Dell Vostro 1320 USB Port Replacement: 13 단계, 이미지 2/2
    • Gently lift out the USB port.
결론
Christie Lloyd
회원 가입일: 08/26/15
431 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 13
전체 시간: 647
