주요 콘텐츠로 건너뛰기
Dell XPS 13 9310 SSD Replacement
필요한 것
  1. Dell XPS 13 9310 SSD Replacement, Unfasten the lower case: 1 단계, 이미지 2개 중 1개 Dell XPS 13 9310 SSD Replacement, Unfasten the lower case: 1 단계, 이미지 2개 중 2개
    • Use a T5 Torx screwdriver to remove the eight 3.3 mm screws securing the case.
  2. Dell XPS 13 9310 SSD Replacement, Insert an opening pick: 2 단계, 이미지 2개 중 1개 Dell XPS 13 9310 SSD Replacement, Insert an opening pick: 2 단계, 이미지 2개 중 2개
    • Insert an opening pick between the lower case and the chassis on the front right edge.
  3. Dell XPS 13 9310 SSD Replacement, Release the case's front clips: 3 단계, 이미지 2개 중 1개 Dell XPS 13 9310 SSD Replacement, Release the case's front clips: 3 단계, 이미지 2개 중 2개
    • Slide the pick along the front edge to release the clips securing the lower case.
  4. Dell XPS 13 9310 SSD Replacement, Release the remaining clips: 4 단계, 이미지 3개 중 1개 Dell XPS 13 9310 SSD Replacement, Release the remaining clips: 4 단계, 이미지 3개 중 2개 Dell XPS 13 9310 SSD Replacement, Release the remaining clips: 4 단계, 이미지 3개 중 3개
    • Continue sliding the opening pick along the perimeter of the lower case to release the remaining clips.
  5. Dell XPS 13 9310 SSD Replacement: 5 단계, 이미지 3개 중 1개 Dell XPS 13 9310 SSD Replacement: 5 단계, 이미지 3개 중 2개 Dell XPS 13 9310 SSD Replacement: 5 단계, 이미지 3개 중 3개
    • Lift the lower case from the chassis and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
  6. Dell XPS 13 9310 SSD Replacement, Disconnect the battery: 6 단계, 이미지 3개 중 1개 Dell XPS 13 9310 SSD Replacement, Disconnect the battery: 6 단계, 이미지 3개 중 2개 Dell XPS 13 9310 SSD Replacement, Disconnect the battery: 6 단계, 이미지 3개 중 3개
    • Grip the pull tab on the battery connector with your fingers and gently pull away from the socket to disconnect it.
    • After you disconnect the battery, some of your laptop's startup (BIOS) settings will revert to their defaults.
    • You may need to run BIOS setup to reset the system clock as well as any specialized disk settings before you can boot up your XPS.
  7. Dell XPS 13 9310 SSD Replacement, Loosen the antenna wire: 7 단계, 이미지 3개 중 1개 Dell XPS 13 9310 SSD Replacement, Loosen the antenna wire: 7 단계, 이미지 3개 중 2개 Dell XPS 13 9310 SSD Replacement, Loosen the antenna wire: 7 단계, 이미지 3개 중 3개
    • Use the flat end of a spudger to pry up and loosen the antenna wire from the SSD cover.
    • Repeat this process along the entire edge of the SSD cover.
  8. Dell XPS 13 9310 SSD Replacement, Unfasten the SSD cover: 8 단계, 이미지 2개 중 1개 Dell XPS 13 9310 SSD Replacement, Unfasten the SSD cover: 8 단계, 이미지 2개 중 2개
    • Use a Phillips screwdriver to remove the 3.6 mm screw securing the SSD cover
  9. Dell XPS 13 9310 SSD Replacement, Remove the SSD cover: 9 단계, 이미지 3개 중 1개 Dell XPS 13 9310 SSD Replacement, Remove the SSD cover: 9 단계, 이미지 3개 중 2개 Dell XPS 13 9310 SSD Replacement, Remove the SSD cover: 9 단계, 이미지 3개 중 3개
    • Pull the SSD cover away from its fastener to remove it.
  10. Dell XPS 13 9310 SSD Replacement, Remove the SSD: 10 단계, 이미지 3개 중 1개 Dell XPS 13 9310 SSD Replacement, Remove the SSD: 10 단계, 이미지 3개 중 2개 Dell XPS 13 9310 SSD Replacement, Remove the SSD: 10 단계, 이미지 3개 중 3개
    • Pull the SSD out of its socket and remove it. Keep the SSD as parallel to the motherboard as possible when pulling on it.
    • Do not pull up at a sharp angle, as this could damage the SSD and the socket.
  11. Dell XPS 13 9310 SSD Replacement, Reassembly notes: 11 단계, 이미지 1개 중 1개
결론
Take your e-waste to an R2 or e-stewards certified recycler.
Repair didn't go as planned? Try some basic troubleshooting, or ask our Dell XPS answers community for help.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Spencer Day
회원 가입일: 09/14/22
149,751 평판
안내서 995개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,629개를 작성함
1가이드 댓글
Please keep in mind to take out any sd card. I permanently have an sd card in the slot, and because it totally disappears inside, i didn't think about removing it. I can tell you it completely ruins both your sd card and the sd card reader
matthias de bruijne - 답글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 36
지난 30일: 175
전체 시간: 6,425
