주요 콘텐츠로 건너뛰기
Dell XPS 13 9365 2-in-1 Battery Replacement
필요한 것
  1. Dell XPS 13 9365 2-in-1 Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Use a Torx T4 screwdriver to remove the eight screws (M2x3) that secure the base cover to the palm-rest assembly.
  2. Dell XPS 13 9365 2-in-1 Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Use your fingertips to lift the system badge open and reveal the single case screw.
    • Use a Phillips #000 screwdriver to remove the screw (M1.6x4) that secures the base cover to the palm-rest assembly.
  3. Dell XPS 13 9365 2-in-1 Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Starting from the front corner of the computer, pry up the base cover using a spudger and lift the base cover off the palm-rest assembly.
  4. Dell XPS 13 9365 2-in-1 Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Disconnect the battery cable from the system board.
  5. Dell XPS 13 9365 2-in-1 Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Use a Phillips #000 screwdriver to remove the two screws (M1.6x4) that secure the battery to the palm-rest assembly.
  6. Dell XPS 13 9365 2-in-1 Battery Replacement: 6 단계, 이미지 1개 중 1개
    • Use a Phillips #000 screwdriver to remove the six screws (M2x3) that secure the battery to the palm-rest assembly.
  7. Dell XPS 13 9365 2-in-1 Battery Replacement: 7 단계, 이미지 1개 중 1개
    • Lift the battery off the palm-rest assembly.
결론
다른 18명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Johnathan Hammond
회원 가입일: 02/28/18
45,216 평판
안내서 408개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
43 회원들
안내서 1,985개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 24
지난 30일: 82
전체 시간: 14,983
