주요 콘텐츠로 건너뛰기
Dell XPS 14 Battery Replacement
필요한 것
  1. Dell XPS 14 Battery Replacement, Back Panel: 1 단계, 이미지 1/1
    • Position the computer back side up so that the “XPS” logo is facing you.
    • Remove six 3 mm screws along the perimeter of the back panel using a T5 Torx screwdriver.
  2. Dell XPS 14 Battery Replacement: 2 단계, 이미지 1/3 Dell XPS 14 Battery Replacement: 2 단계, 이미지 2/3 Dell XPS 14 Battery Replacement: 2 단계, 이미지 3/3
    • Use an opening tool to pry up the metal plate.
    • Remove the two 6 mm screws under the silver flap using a Phillips #0 screwdriver.
  3. Dell XPS 14 Battery Replacement: 3 단계, 이미지 1/2 Dell XPS 14 Battery Replacement: 3 단계, 이미지 2/2
    • Use an opening tool to pop out the back panel.
    • Once unhinged, the panel will open away from you.
    • The back panel will still be attached by a ribbon cable. Be cautious when opening the panel to ensure the ribbon stays intact.
  4. Dell XPS 14 Battery Replacement: 4 단계, 이미지 1/3 Dell XPS 14 Battery Replacement: 4 단계, 이미지 2/3 Dell XPS 14 Battery Replacement: 4 단계, 이미지 3/3
    • Flip over the back panel so that the interior of the panel is facing up.
    • Remove three 2 mm screws that are connected to the vendor GCE disk on the bottom left corner of the back panel using a Phillips #0 screwdriver.
    • Remove the black plastic cover that holds the disk in place.
    • Remove the back panel.
    • The GCE disk should still be connected to the computer via a purple ribbon cable.
  5. Dell XPS 14 Battery Replacement, Speaker: 5 단계, 이미지 1/2 Dell XPS 14 Battery Replacement, Speaker: 5 단계, 이미지 2/2
    • Remove four 2 mm screws that are connected to the speaker using a Phillips #0 screwdriver.
  6. Dell XPS 14 Battery Replacement: 6 단계, 이미지 1/2 Dell XPS 14 Battery Replacement: 6 단계, 이미지 2/2
    • Remove the speaker from its original location so the wire connector is visible.
    • Unplug the red and white cable plug by pulling out the white end tag.
    • The speaker is now fully removed.
  7. Dell XPS 14 Battery Replacement, Battery: 7 단계, 이미지 1/1
    • Make sure to ground yourself before removing the battery.
    • Remove the four 6 mm screws from the sides of the battery using a T5 Torx screwdriver.
    • Remove the two 3 mm screws from the top of the battery using a Phillips #0 screwdriver.
  8. Dell XPS 14 Battery Replacement: 8 단계, 이미지 1/3 Dell XPS 14 Battery Replacement: 8 단계, 이미지 2/3 Dell XPS 14 Battery Replacement: 8 단계, 이미지 3/3
    • Detach the battery connector from the motherboard using two thumbs to pop it out.
    • Remove the battery from the laptop.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Gabriella Monico
회원 가입일: 03/23/22
457 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 1-3, Botvin Spring 2022 UMass Dartmouth, Team 1-3, Botvin Spring 2022 회원
UMASSD-BOTVIN-S22S1G3
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 30
전체 시간: 851
