주요 콘텐츠로 건너뛰기
Dell XPS 14 L401X Battery Replacement
필요한 것
  1. Dell XPS 14 L401X Battery Replacement, Battery: 1 단계, 이미지 1/2 Dell XPS 14 L401X Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Make sure that the laptop is shut off before attempting to remove any components from the device.
    • The laptop in this example did not have a battery equipped.
    • Locate the spring latch on the bottom of the device that will unlatch the battery.
    • Hold the spring latch in the open position and pull the battery out of its recess.
결론
For optimal performance, after completing this guide, calibrate your newly installed battery.
Mark
회원 가입일: 10/19/17
643 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team S4-G3, Julie Fall 2017 UMass Dartmouth, Team S4-G3, Julie Fall 2017 회원
UMASSD-JULIE-F17S4G3
3 회원들
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 5
전체 시간: 694
