주요 콘텐츠로 건너뛰기
Dell XPS 15 9510 Fan Replacement
필요한 것
  1. Dell XPS 15 9510 Fan Replacement, Rear Panel: 1 단계, 이미지 1/1
    • Make sure the laptop is powered off and unplug all cables before beginning any repair.
    • Remove eight 3 mm screws from the underside of the case using a T5 Torx screwdriver.
  2. Dell XPS 15 9510 Fan Replacement: 2 단계, 이미지 1/1
    • The metal case of the XPS 15 9510 is extremely sharp, so be careful not to run your fingers along the edge when disassembling the laptop.
    • Wedge the case apart with a nylon spudger.
    • If the plastic one isn't possible to insert, use the metal spudger to carefully create a small gap first.
    • Slide spudger along each side of the laptop
  3. Dell XPS 15 9510 Fan Replacement: 3 단계, 이미지 1/1
    • Lift the back panel of the laptop off and set it aside.
  4. Dell XPS 15 9510 Fan Replacement, Fan: 4 단계, 이미지 1/2 Dell XPS 15 9510 Fan Replacement, Fan: 4 단계, 이미지 2/2
    • Remove two 4.3 mm screws from the left fan and one 4.3 mm screw from the right fan using a JIS #000 screwdriver.
  5. Dell XPS 15 9510 Fan Replacement: 5 단계, 이미지 1/2 Dell XPS 15 9510 Fan Replacement: 5 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Gently unplug the motherboard fan connector using a pair of tweezers.
  6. Dell XPS 15 9510 Fan Replacement: 6 단계, 이미지 1/1
    • Unplug the motherboard connector on the other fan using a pair of tweezers.
  7. Dell XPS 15 9510 Fan Replacement: 7 단계, 이미지 1/2 Dell XPS 15 9510 Fan Replacement: 7 단계, 이미지 2/2
    • Gently slide and then lift the fans out of their positions.
  8. Dell XPS 15 9510 Fan Replacement: 8 단계, 이미지 1/3 Dell XPS 15 9510 Fan Replacement: 8 단계, 이미지 2/3 Dell XPS 15 9510 Fan Replacement: 8 단계, 이미지 3/3
    • Repeat the previous step and remove the other fan.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Bethany Wright
회원 가입일: 07/13/23
403 평판
안내서 3개 작성하였습니다
IUPUI, Team 2-1, Harley Summer 2023 IUPUI, Team 2-1, Harley Summer 2023 회원
IUPUI-HARLEY-SU23S2G1
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 42
전체 시간: 607
